Half Moon Seals
Old Feb 8, 2010 | 05:30 PM
MARCOSWORTH's Avatar
MARCOSWORTH
Default Half Moon Seals
Hi,
Is this the stuff to seal the half moon seals on a Cosworth??
HYLOMAR PL32M
Thanks in advance
Old Feb 8, 2010 | 05:51 PM
jon@work's Avatar
jon@work
That's what I use. Not had a leak yet.
Old Feb 8, 2010 | 06:26 PM
It will work, but if you buy Loctite 5900 or 5910, you'll never look at Hyloamr again, and be able to use it on a lot more things, glass wood plastic fibreglass carbon ceramic metal bricks etc etc.
Old Feb 9, 2010 | 05:02 AM
MARCOSWORTH
Cheers guys
@ tabetha can i also use this loctite instead of epoxy to ''glue'' the pipe for the breather in the camcover, i've read the specs of it and i think it will work???
Old Feb 9, 2010 | 09:20 AM
Yes will do the job perfectly, but you will have a fight on your hands if you ever want to take it out again!!
I have bookshelf supports held on with this stuff, with 3 model cars 1/10 lecky ones plus controllers on it plus spares etc, radio papers other odds and sods!!
Old Feb 9, 2010 | 02:56 PM
MARCOSWORTH
How long does it take for the Loctite to harden to full strenght??
Old Feb 9, 2010 | 03:05 PM
Dave Hewy's Avatar
Dave Hewy
I used this stuff and it worked a treat. You can buy it at any A1 motor store. http://www.motoressentials.co.uk/epa...oducts/rtv-red
Old Feb 9, 2010 | 04:16 PM
If you use the quick setting one(5910) then about 10 minutes, the other around 1 hour(5900).
There is a reason why this stuff is expensive, a tube of around 300ml is somewhere in the region of £18-£22.
Old Feb 9, 2010 | 06:11 PM
Toe Knee's Avatar
Toe Knee
is that the one tabs?!
http://www.halfords.com/webapp/wcs/s...egoryId_165691
if it is thats what u reccomended that u used on the bolt i fitted to the back of the blocks!! think with my trade card was about £3 odd for a 80ml tube in halfords!
Old Feb 9, 2010 | 09:14 PM
kcosneil's Avatar
kcosneil
i use locctite 5910 never fails. evan use it instead of theromasat and water pump gasket. no leaks!
Old Feb 10, 2010 | 05:17 AM
MARCOSWORTH
Thanks for the comments, just ordered some Loctite at my work yestreday
Old Feb 10, 2010 | 07:56 PM
Yes that's the stuff, my local halfords doesn't sell it, looked at my tube today, it is 1500ml, god knows where I got 300 from!!
Old Feb 12, 2010 | 03:47 PM
MARCOSWORTH
Got mine today, only €13,02 for 200ml
Old Feb 13, 2010 | 10:57 PM
SS1's Avatar
SS1
Also sold on ebay if you carnt find any local to you
http://cgi.ebay.co.uk/Loctite-5910-H...item19b99a4ea1
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
