uncontrollable revving problem.
Old Feb 8, 2010 | 04:47 PM
tazabella1's Avatar
tazabella1
Default uncontrollable revving problem.
Im having a little problem with my Ka. I think she's a 93 1.3..... make sense???
Whilst driving when i have my foot is fully on the clutch my car is revving uncontrollably.. its getting really loud and lasts about a full 10 seconds.....
It is quite worrying as ill soon be driving to work and don't want anything happening to my car.....
Any help would be greatly appreciated....
Thanks
Old Feb 8, 2010 | 04:59 PM
nicksaph's Avatar
nicksaph
if i remember right there was a special notice from ford about this, about a new modifyed throttle position sensor,
will look see tomorrow through my paperwork and let you know
cheeRS nick
focusrsred's Avatar
focusrsred
There is an over-run switch on the clutch pedal iirc. Might have something to do with it? Only similar problem I ever had was down to a lambda sensor, but that was bad all the time not just with the clutch down
Old Feb 8, 2010 | 07:18 PM
nthorpey's Avatar
nthorpey
sounds like idle speed control valve stuck to me, take it off and give it a good clean out
Old Feb 8, 2010 | 07:26 PM
danzul's Avatar
danzul
i had a similar problem on my old escort, check the vacuum hoses for splits or holes,
Old Feb 8, 2010 | 07:34 PM
TOMMY_RS's Avatar
TOMMY_RS
SHITE!
my dads car used to do this
would rev and shoot forward at traffic lights etc, bastard thing
Old Feb 8, 2010 | 07:39 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
My mates 1.3 fiesta did this after he went through a rather large puddle a bit fast. New throttle position sensor (old one was full of water) and it was fine.
Old Feb 9, 2010 | 09:32 AM
Could be tps but unlikely imo, it could be the speed sensor gone duff, and not telling the ecu the car is stationary, what sort of rpm do you see, the idea of the speed sensor, which is seprate from the speedo sensor is to hold the revs higher than idle when chaging gear etc to help smoother changes.
Old Feb 10, 2010 | 12:07 PM
nicksaph's Avatar
nicksaph
i have found the ford technical bullitain but it is for later ka's than yours(96 on) and it is for "idle speed hang up during gear change" which in laymans teams means engine revs uncontrollable during gear changes.
and it recomends fitting a modified throttle position sensor multi plug, finis code 1 150 138.
i can scan the sheet and post it up here if you want as it explaines how to do the job.
cheeRS nick.
Old Feb 10, 2010 | 04:33 PM
XRSTI's Avatar
XRSTI
unplug the speed sensor plug on the speedo at the gearbox that will sort it out
Old Feb 10, 2010 | 04:37 PM
kitted_escort's Avatar
kitted_escort
Have a look at ur beather pipes
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
kosienutter
31
Aug 22, 2015 09:55 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
Adam-M
22
Aug 10, 2015 10:46 AM
