07 transit diag port
Gary Krishna
Under the steering column behind a plastic trim mate. Just pull of the trim and you will see it.
I'd put money on it being an EGR valve issue. It's so common we keep them in stock on our vans!! Lol!
you need to give it a good old yank to pop the clips
then it's just by your shin right shin
and yes, egr valve for the win
http://www.fordmondeo.org/forum/show...00877/#1900877
check out some pics here
it might come up on the tester about watering in the fuel filter. Just ignore this error code cause its whats called as a ghost code. There is no sensor in the bottom of the fuel filter.
EGR valve is almost guaranteed to be at fault !
Fitted quite a few of them recently, also had loads with water in the fuel filter causing all sorts or running concerns, mainly a lack of power so wroth checking the filter just in case.
we had one that had a split diaphram in the fuel pump lifter or seomthing to that effect
would go into limp home mode when you floored it, but if you switched it on and off again it would clear the fault code
took MONTHS for that to get fixed
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
