compression readings ?
Old Feb 7, 2010 | 08:49 PM
muttsnutts89's Avatar
muttsnutts89
Smile compression readings ?
hi what sort of compression figure should i have from my 89 erst 1600cvh ? a figure for a bad engine compared to say a good rebuilt one thanks.
Old Feb 8, 2010 | 05:11 AM
JesseT's Avatar
JesseT
Equal! That is of primary importance. The value is secondary and can easily be affected by settings, such as cam timing.
On a standard engine, I'd say that the compression reading in bars should be higher than the compression ratio. On wild cams these tend to be on the same level.
Old Feb 8, 2010 | 06:21 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
i good one should be 150 psi in each cylinder
Old Feb 8, 2010 | 07:05 PM
muttsnutts89
the reason i ask is just done a egine rebuild on my rs. new rings, re seat valves and head skim, big and main bearings full gasket set ect.. it also has got a kent cam cvh 35 and all running great and checked the compression and i have 8.5 bar (125psi) on all clinders does this sound a little low ?? .................... regards ryan
Old Feb 9, 2010 | 05:07 AM
JesseT's Avatar
JesseT
You will not get much higher on a CVH35. All is ok.
Old Feb 9, 2010 | 06:24 AM
rickbartlett
G911 TTA
seems a little low to me
Old Feb 9, 2010 | 09:13 AM
If it's a very new engine give it some time to bed the rings in properly, don't worry about the comp, just as said so long as nice and even.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Iain Mac
Sep 30, 2015 09:39 PM
