Steering Vibrates loudly when braking
Old Feb 7, 2010 | 07:42 AM
Digijtal's Avatar
Digijtal
Default Steering Vibrates loudly when braking
I've been having this problem for months now. When I apply the brakes on my 1992 Ford Fiesta mk3 1.8d the steering seems to vibrates very loadly at high speeds (>60km/h).Also when the car is moving slowly in traffic and the brakes are applied the car seems to accelerate and decalerate, as if the brake discs are warped, but this is not the case as I have checked for this using a dial Gauge, and it gave me approx. 0.2 mm run-out. I reallly don't know what to do next. If someone could help it would be really appreciated. 10x
Old Feb 7, 2010 | 08:38 AM
AndyST's Avatar
AndyST
You've already exceeded the max of 0.05mm runout mate, get the discs and pads renewed.
Old Feb 7, 2010 | 09:46 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, new discs needed pal.
it doesn't take much to get them vibrating.
Old Feb 7, 2010 | 09:57 AM
stevostyles's Avatar
stevostyles
every time ive had this its been warped discs on the front and if not felt through the steering wheel its at the rear.
most common cause for me is hard braking but can be due to pads/ even a caliper.
Old Feb 8, 2010 | 05:15 PM
Digijtal's Avatar
Digijtal
10x alot 4 the help guys!! much appreciated.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
