Fuel line connector
Old Jan 6, 2005 | 04:46 PM
C0S_TURBO's Avatar
C0S_TURBO
Default Fuel line connector
2WD Saph Cosworth (Stage 3)
I have broken the black connector (situated under water bottle on inside of the chassis) which connects the plastic return pipe from the fuel rail to the metal fuel pipe that returns to the fuel tank. Ford tell me this part is no longer available. Any ideas?
Many Thanks
Old Jan 6, 2005 | 08:14 PM
dark3drcos.kickass's Avatar
dark3drcos.kickass
i had same prob just got pipe from halfords came with clips and everything i was scepticle but ok so far but i have only drove it once since so not as yet reccommended but an idea
Old Jan 7, 2005 | 03:50 PM
CosKev3's Avatar
CosKev3
Mines just got standard fuel pipe,works as it should
Old Jan 9, 2005 | 01:28 AM
bortaf's Avatar
bortaf
probably running less pressure? but on me injection pinto i just used hi pressure rubber pipe and those bolt up clips (2) on each connection for the return from the fuel rail.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
Fudgey
Sep 17, 2015 01:06 PM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
