Escort RS2000 Van Project 56k Geta LiFe
I thot id start a seperate post seen as the last time aye put the pics of it in with my fiesta project so here goes a seperate throad for my wee work horse as am gawney be doing a few more mods to it in the next week or two heres how it started
When i got it ex securicor no door panels 2 diffirent front seats dash all paint aswell as inside one plastic window on drivers side and fuked up rusted bodywork
So new loom with central locking eclectric windows and so all the doors and igntion start from the one key aswell as a full new interior
Then it was time to sort out the bodywork
Then i lowerd it
Plus stone chiped it and waxed it
Then it got painted
Then built back up
Then stickerd up
How it looks the now "15 406 steelies done candy lime green over sparkle silver
Thinking of putting these on it in candy green
also got rs2000 sideskirts coming , smoke headlights , rs2000 recaros , rs2000 running gear , full service kit plus timing chain and loads of goodies watch this space
Then i lowerd it
Then it got painted
Then built back up
Then stickerd up
well the engine arrived and no messing about got the old engine rippd out and started sorting the rs2000 loom out still on the wiring another shift should kill that then the engine will fall in
You have done yours the other way to me, body first then engine. I must say yours prior to being badged up is almost exactly how I want mine to look. Keep the pictures coming ! Chris
i think i got it sorteed mate well not those wires the ones for the fuel pump and keytransponder i was missing 2 bits of loom one that plugs into the multiplug next to the ecu then goes onto the transponder and the loom that goes from the tailgate lights to the fuel pump to the fuse box ! so iam gawney stick the engine in now fire the new looms in and try fire her up that way ill no wat those wires that have been cut are for anything
small update got the new brakes and that on plus the engine in still on the wiring at the moment ive dun away with the aircon as it will save a bit of weight sum pics
should hopefully be running by the weekend
well after getin the engine in started connect the loom to bits in it didnt match up only to find out it i was missing 3 parts of the loom so got them all changed them over couldnt get a hold of a petrol escort van tank until april so aye bought a disel one and modified it haha had it fired up the other day but the lights are fuked theres a ground sumwhere or av missd one could be a rely aswel only one side ae the hazards work and you get a buzzing sound wen you put them on ill get it sorteed tho gt a set of rs2000 skirts and powderd my fiesta cossy wheels am gawney stick them on the van dun them candy green but decided to change them to illuminous green with a white lip sum pics
how the inside is looking lol
wee pic of my mates r1 street fighter with sum air brushin
hi mate i sold the fezzy turbo on to a mate you can view his build here http://www.westofscotlandrsoc.net/fo...hp?f=17&t=6532 i didnt really have time to finish it when i started up my own buisness i work constant and till late at nite time i get in washed and dinner its time to go to bed for work again lol hopefully i will grow and can pay other people to work for me
hi woundered if you could help me i have put a mk 6 rs2000 engine in my escort gti 1.8
but im having trouble with the wiring loom there is two wires coming off the top gearbox and there is also two wires coming from the teromsate housing and these wire all go into one big plug and there is no where to plug it into on my car and the wires that come from the ecu loom to the key chip there is 8 wires off the rs2000 loom and only 6 on the loom that is on my car.
many thanks yvonne
many thanks yvonne
hi mate you need the headlight loom from a rs 2000 to sort out the gearbox wire(reverse light) and the one on the thermostat theres actually 2 one for your temp and one to cut ur fan on am sure that headlight loom will give u the end for the multiplug to plug into and theres a small loom abt a metre long tht runs from the key transponder to a multiplug on that headlight loom that does away with the pats box
the vans been up and running now for the last month with no problems touch hairy wood lol i done 2 wheel bearings 2 bottom arms 2 drop links 2 track rod ends and got the tracking done so its pulling nice an d straight just my sideskirts and revy wheels to go on :d
well av been a bit busy to update this so here goes vans totally finished with everything all working ie:no water leaks oil leaks , fan cutting on and off blah blah blah , taxd , motd , new wheels sideskirts done just not fitted put the wheels on yesterday kinda stretched tyres and the stick out miles by the bodywork lol engine ran sweetly for the last month n half touch hairy wood lol pics ur shite there just off ma phone they dnt do that green any justice on the wheels it really is a bright iluminous green
revoloution wheels there 15 inch they did have racing slicks on them they wer off my fiesta cosworth ive been told there quite rare and worth a bit am not sure tho
wee update removed the egr valves made up a decat pipe in heat wraped them gawney stick a new passanger side drive shaft as a hink mines is warped everytime you go er 40 its like hittin warp speed in the delorian either that or a engine mount av got spares ae them anawl so here hopin
in a wee pic ae ma plate on ma old raptor
pc plod will love you and those wheels stickin out past the archs lol put a maga stretched tyre onit and youll get away with it or put arch extensions onit like 206 arches etc saw them on a few escoert vans.looks great tho mate.
