Escort RS Turbo S2 interior blower problem
Old Feb 5, 2010 | 03:56 PM
paulospug's Avatar
paulospug
RS Doer!!!!
Default Escort RS Turbo S2 interior blower problem
My S2 still will not work on the interior fan.
I have of course taken the plug off to the actual blower under the bonnet but no power. There is no power behind the dash switch on the speed variator either.
Where do I go to now to check for power and do they have a relay somewhere under the dash?
Shame as it's the only thing that lets my grey RS down - never has worked!
Thanks for any help.
Paul
Old Feb 5, 2010 | 07:56 PM
if you've checked the obvious fuses connections etc, then simplest thing to do is take a wire from position 2 of the ignition switch itself where it outputs to lecky in pos 2, take this live to speed switch, all else being ok will then work.
The supply for the front fogs on my sapphy disapeared so I just branched over to the rear fog switch supply, just not worth ripping the car to bits to find the broken wire/connection.
Old Feb 5, 2010 | 09:55 PM
paulospug's Avatar
paulospug
RS Doer!!!!
Nice one.
Didn't think of that. She's in a garage locally getting mot'd and having sump gasket done (tried twice, but still leaked ) so now paying for it to be done.
When I get her back in my loving arms, I'll do it that way.
Old Feb 6, 2010 | 02:04 PM
NO probs matey, shout if still being naughty!!
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
adriansaleem
Aug 1, 2015 09:28 PM
Old ford
Jul 31, 2015 06:50 AM
