Basemap needed
Old Feb 2, 2010 | 08:29 PM
dexspeed's Avatar
dexspeed
Default Basemap needed
hi i have a little zetec turbo project
im using megasquirt 2 v3.0 ecu i need basemap
engine displacement : 1833cc
Cylinder Head : 2.0 zetec cylinder head
Turbocharger : t3/t4 0.50 trim
Injectors 240sx : 550cc
Wossner comp. ratio : 8.0.1
Rods : Eagle H-Beam rods
Exhaust manifold : Horn style
Old Feb 3, 2010 | 09:02 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i can give you my 1.8zvh map using hi impedance 440cc injectors
on a cossie turbo, obviously it's only a base, but should get it fired up, just may need to adjust req fuel to get it to idle close, then tune from there.
edit to say i'm on extra code 2.1.1 with bigger ve table, you'd have to flash the firmware and upgrade to use my map.
Old Feb 3, 2010 | 09:03 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
why not just let the MS software generate you a basemap, will be enough to fire it up on IME and then you can map it properly.
Old Feb 3, 2010 | 05:07 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i don't know anyone that's had success with the software doing it anywhere close.
usually the required fuel calculations are way too high and it still leaves the priming and cranking fuel settings to still be inputted.
it's not that hard to get it started IMO.
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
Escortdriver1
Aug 19, 2015 09:02 PM
col93saphcos
Aug 7, 2015 03:21 PM
