Master Cylinders ERST
Old Feb 2, 2010 | 07:39 PM
drsrst2zvh's Avatar
drsrst2zvh
Default Master Cylinders ERST
Right i have the same problem as everyone else. I have a "25" Master Cylinder and its started weeping from the rear i know you cant get parts for them or the cylinders themselves, but what i need to know is can you use the 22 or 23 cylinders with the rst servo and also if they will be ok to use with my brake set-up, standard rears and cossie 4 pot fronts?
Old Feb 2, 2010 | 07:55 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
Big Red do the rebuild kits for them matey.
I will try and get the part number and details for you.
CheeRS
Chris
Old Feb 2, 2010 | 08:10 PM
drsrst2zvh's Avatar
drsrst2zvh
I dont think you can still get the rebiuld kits for the original 25mm bore cylinders I know you can get them for the 23 and 22mm ones but ill need to buy a new cylinder anyway
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
muzzman1
Sep 30, 2015 08:59 PM
