Updating S.E.C.S Monitor
Old Mar 12, 2004 | 01:22 AM
Default Updating S.E.C.S Monitor
Is there new software avalible for the secs monitors?
Is it a simple case of uploading new software to the monitor via PC/Laptop.
Could you run a Nitrous Arming switch off the monitor so when the TPS hits 100% it arms? Replacing the job of the micro switch on the throttle body?
Rich
Old Mar 14, 2004 | 01:02 PM
PJay's Avatar
PJay
Not sure TBH would be best to phone Simon
I wouldn't have thought so
It MAY be possible, i know SECS has built in ALARM settings although i don't know of it has one for the TPS
Old Mar 18, 2004 | 12:08 PM
on my secs I use the water injection to trigger a timeing rely that keeps on for 6 minuts.
It was for a homebuild charge cooler kit , (Build it for fun, and did not work ).
Anyway there are 2 parameters that trigger the water injection;
Boost level and air temp .
There is a 0-100% reading at the secs monitor but it's just a read out, not a controler device!
TPM961
Jan 15, 2018 10:50 AM
pabloXR
Sep 21, 2015 12:42 PM
Roscopeco
Sep 14, 2015 05:32 PM
