Boost on fiesta rst
Old Feb 2, 2010 | 05:54 AM
rsdan2evn's Avatar
rsdan2evn
Default Boost on fiesta rst
I have a fiesta rst and just wondering what it should be running on standard boost? And whats the safest this can be raised to, and how do you go about it?
Old Feb 2, 2010 | 06:07 AM
ROB7656's Avatar
ROB7656
standard boost is 7.2 psi.you will need to get a tuner to get your car to run higher boost safely as the fueling needs to be increased to match. you can run a bit more boost with standard parts but idealy youl need chip actuator and setup by a pro or it could be a ticking time bomb!!!!
Old Feb 2, 2010 | 12:47 PM
martysmartie's Avatar
martysmartie
You need a suitable remapped chip to start with before anything, if you try to raise boost now not only will it destroy your engine and experience overboost protection.
Stage 1 165 named so because that is the claimed power it's supposed to give, will be easiest as it just requires a chip and boost adjustment. This will see around 160HP + ATF on a good setup/engine.
Stage 2 is 195 chip again meaning the claimed power, beige denoting the colour injectors (701's) to be used. This will make around 170-180 HP + again dependent on engine condition.
Martin
JK12
33
Apr 26, 2021 12:09 PM
89barto89
Oct 4, 2015 06:59 PM
A.t.p
Sep 29, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
Billy_RS
Sep 13, 2015 04:17 PM
