KA water leaks
Old Feb 1, 2010 | 08:20 PM
Default KA water leaks
Help I can't swim, and need to in this 2000 year KA, serious amount of water everywhere in front footwells, defo not matrix as uses no water at all, drivers side much worse, is there any common water leak areas known on these, where is the drain tube for the air con, as this is used a lot so maybe also blocked tube, assume it's in the centre under the area somnewhere.
Any help appreciated as always, thanks.
Old Feb 1, 2010 | 09:22 PM
xrsi's Avatar
xrsi
the ex's (say ex, current partner but seperated at min) KA does this...
was going to look at it but couldnt be arsed, i assumed it was bad sealing round the screen.
Old Feb 1, 2010 | 09:25 PM
Dlatch!'s Avatar
Dlatch!
would poss get leak if screen is a replacement, also try putting a very bright light shining towards the bulkhead and check from inside anywhere u can see light coming through, leaks are a right pain to track down sometimes
Old Feb 1, 2010 | 09:38 PM
dangerousbrian's Avatar
dangerousbrian
im a screen fitter and its quite common on these..also under and around the scuttle is prone to corrosion and causes leaks under the glass
Old Feb 1, 2010 | 09:46 PM
jammy86's Avatar
jammy86
Theres a bit grommet on either side of the engine bay towards the rear behing the header tank (left or right depending on engine) that perrishes or if the car is second hand, someone might have stuck some cabling down. Leaks like a f00ker, even if its only a tiny little crack in it.
hth
JAmes.
Old Feb 2, 2010 | 05:01 PM
HI,
I did wonder about the screen, but it is the oe one SEKUR IT job, think it's rip the car to bits time, thanks for suggestions.
Old Feb 2, 2010 | 05:04 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
the air con drain tube is by the centre consal, ive had loads where they come out and fill the car up
Old Feb 2, 2010 | 07:57 PM
Thanks for that, about the air con pipe, I didn't even know you could get air con on these, even has leather!!
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
