pressure in water bottle ?
Old Jan 31, 2010 | 06:49 PM
xr3i_kev's Avatar
xr3i_kev
Default pressure in water bottle ?
i have just put new water pump headgasket timing belt etc on my car
it now runs and fine when idleing but when accelerating
there is a lot of pressure coming out of the bottle
under heavy acceleration it blew of the radiator hose that i hadnt tightened properly .
i had to bypass the heater matrix yesterday due to it bursting
could this be the main cause ?
its a 1998 escort gti ?
any ideas before i smash it up with a hammer lol
cheers kev
Old Jan 31, 2010 | 06:56 PM
cossiegreg1's Avatar
cossiegreg1
head gasket
Old Jan 31, 2010 | 06:57 PM
xr3i_kev's Avatar
xr3i_kev
Originally Posted by cossiegreg1
head gasket
just changed this ???
Old Jan 31, 2010 | 06:59 PM
focusv8's Avatar
focusv8
Cracked or distorted head.
Old Jan 31, 2010 | 07:01 PM
MadMac's Avatar
MadMac
There usually is a pressure build up in the cooling system as the water is heated, it wants to turn to steam, but because is a closed system and wont let any of it out you get a pressure build up.
I would say if a hose popped off because you didn't tighten it up properly its quite normal.
Old Jan 31, 2010 | 07:08 PM
cossiegreg1
did you get the head skimmed/ check for flatness
Old Jan 31, 2010 | 07:14 PM
xr3i_kev's Avatar
xr3i_kev
got a full skim etc on the head ?
Old Jan 31, 2010 | 07:16 PM
RichieST's Avatar
RichieST
Still sounds rather fucked. With it warm and running, open the cap and see if bubbles are coming up through.
Old Jan 31, 2010 | 07:22 PM
xr3i_kev's Avatar
xr3i_kev
when it idles with the cap off to satrt with there was bubbles couming up
when giving it revs the water goes down
then put the cap on it starts to pressurise the pipes are solid then switch it off and start to release cap it hissess
Old Jan 31, 2010 | 07:24 PM
RichieST's Avatar
RichieST
Sounds to me like head is warped. Did you have it skimmed before refitting?
Old Jan 31, 2010 | 07:27 PM
cossiegreg1
i would get a sniff test done.
did you change thermostat?
Old Jan 31, 2010 | 07:36 PM
xr3i_kev's Avatar
xr3i_kev
not changed thermo stat yet
Old Feb 1, 2010 | 07:33 AM
utternutter's Avatar
utternutter
it will be the head allways skim and test a head before refitting if the cars cooked etc
Old Feb 1, 2010 | 07:46 AM
badnews's Avatar
badnews
cracked block maybe, pressure has to come from somewhere a sniff test will tell you whats going. thermostat is clutching at straws as it would still run ok regardless. bursting a heater matrix and blowing off hoses is a major problem a leak down test would be an idea along with a compression test for a more definate answer. a quick look at the spark plugs should show if it's burning water one will be cleaner to show the problem on that cylinder
Old Feb 1, 2010 | 09:24 AM
AlexF's Avatar
AlexF
Why did you do the HG in the 1st place?
Old Feb 1, 2010 | 08:25 PM
Ellie's Avatar
Ellie
Whats a sniff test?
Old Feb 1, 2010 | 08:31 PM
RichieST's Avatar
RichieST
Originally Posted by Ellie
Whats a sniff test?
Where you get a big pipette thing to 'sniff' up some gases out of the header tank, if there's exhaust gases in there then a chemical inside the pipette will turn a different colour to indacate head gasket failiure!
Old Feb 1, 2010 | 08:34 PM
T3ORA's Avatar
T3ORA
did you fit the right water pump,cous there is 2 types
and was it doing it before you done any thing to it
Old Feb 1, 2010 | 09:40 PM
pee vee's Avatar
pee vee
run the car up to temp with the rad cap off.
then put cap back on and drive it.. see what happens...
sounds like something more major is wrong though sadly..
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
