battery issues
Old Jan 30, 2010 | 04:52 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default battery issues
Been away for a 5 days, went to start the s2 up and had flat battery, so bumped it, went first time, moved it off the drive way was running for 5mins or so, idle mainly, and turned engine off, and went to start it, all its doing is priming fuel pump fine, but wont start.
Everything was fine 5 days ago.
Old Jan 30, 2010 | 05:17 PM
Korda's Avatar
Korda
have you got a spare battery you could try or put yours on charge give that a try first
Old Jan 30, 2010 | 06:09 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
ill charge it over night, its strange as the fuel pump primes fine, but wont even try starting
Old Jan 30, 2010 | 06:11 PM
Korda's Avatar
Korda
it may have enough to prim the fuel pump but not turn over give it a charge tonight
Old Jan 30, 2010 | 06:12 PM
marky_g's Avatar
marky_g
Fleet Manager
id say the cold weather has killed you batt mate buy an hydrometer there only a few quid
fule pump will prime off about 11 volts and low amps to crank u need high amps
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
