Fitting Sierra Adjustable top mounts
Old Jan 30, 2010 | 11:15 AM
Shaggy's Auto Store's Avatar
Shaggy's Auto Store
Default Fitting Sierra Adjustable top mounts
These are the top mounts they i have ordered for my track car. Can anyone tell me if i will need to cut a bit out of my chassis/ strut top to allow them to be adjustable. They havnt arrived yet im just trying to get a picture how they work.. Thanks in advance
Check out my profile for pics so far..
Old Jan 30, 2010 | 11:20 AM
jon@work's Avatar
jon@work
If you look at the position of the circlip holding the bearing in place, you'll notice that these need to be mounted the other way up from that shown in the photo, so you won't need to do anything other than drill mounting holes.
You may have issues with getting the ride height as low as the car currently sits as the bearing is mounted further down than the standard top mount.
Old Jan 30, 2010 | 11:28 AM
Shaggy's Auto Store
So the picture shows them upside down..? Makes more sense now.. Should i cut my strut terrot and lenghen it (move it closer to the bonnet) or is there another way to get it sitting as low again..?
Check out my profile for project pics so far..
Old Jan 30, 2010 | 11:50 AM
jon@work's Avatar
jon@work
As you've got coilovers, you may get away with adjusting the lower spring seat if it is clear of the wheel/tyre, but check that you've still got enough damper travel
matman
Sep 9, 2015 05:45 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
Vincereese
Aug 11, 2015 08:44 AM
