Gearbox probs anyone help?
Old Jan 29, 2010 | 09:45 PM
morph's Avatar
morph
Default Gearbox probs anyone help?
I keep having problems getting the car out of gear to change to next gear, its intermitten and does it more from cold but has also done it when warm but not as much.
if i am in 1st gear and goto change to 2nd its like it wont want to come out of 1st gear, if i double d clutch it finaly releases, it also does it from say 3rd to 4th.
its only really started doing this since i had my b&m short shift fitted but can't say 100% its that! just wondered if it is a problem with the gearbox or clutch?
it has a standard rebuilt gearbox with probably uprated bearings and a 4 paddle clutch with standard pressure plate. i also have fitted a mk6 pedal and new cable but that has not solved the problem, if its the gearbox thats fine as i will shortly be going for a different box but if its not then what could it be? my tuner has said its probably the gearbox main shaft but the gearbox isn't noisey or whining. if the car is off or clutch is pressed in it selects all gears with no problems. its doesn't crunch even in reverse.
thanks
Old Jan 29, 2010 | 09:54 PM
d4 rst's Avatar
d4 rst
DADDY RST
BUY A CTS 2+
Old Jan 29, 2010 | 10:25 PM
project rs's Avatar
project rs
possibly the clutch is not propely adjusted how high is the bite point
Old Jan 29, 2010 | 10:28 PM
s1cab's Avatar
s1cab
thats what i would check 1st
Old Jan 29, 2010 | 10:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like the box to me, as you've done the pedal mod which gives you more clearance.
Old Jan 30, 2010 | 07:22 PM
morph's Avatar
morph
howhigh or low should the clutch be adjusted?
Old Jan 30, 2010 | 08:22 PM
SteveXR2T's Avatar
SteveXR2T
!! Give me a break !!
just under 1/2 a pedal
Old Jan 30, 2010 | 09:00 PM
morph's Avatar
morph
mine is adjusted to about 1inch downwards compared to the brake pedal.
so is this 1/2 a pedal or too little?
Old Jan 31, 2010 | 10:17 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Easiest answer is to put the pedal as high as you can and see if it disengages the gears properly then
Old Jan 31, 2010 | 12:07 PM
morph's Avatar
morph
having the pedal higher means it is more tension on the cable?
cheers
Old Jan 31, 2010 | 01:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No, the spring on the pedal tensions the cable.... a higher pedal will give more travel on the cable.
Old Jan 31, 2010 | 03:08 PM
morph's Avatar
morph
so would it not be better keeping the pedal shorter? so it gives more tension?
Old Jan 31, 2010 | 04:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No, you dont quite get what I mean......
The further the pedal can travel the more cable it pulls, the further the arm on the gearbox moves, and so the more the clutch will disengage!
Old Jan 31, 2010 | 04:30 PM
Rodreguez's Avatar
Rodreguez
sounds like mine b4 i changed the clutch, felt like u had to pop it in gear
Dan
Old Jan 31, 2010 | 06:47 PM
morph's Avatar
morph
Finaly the answer i was looking for! got it! will give that a try
Old Jan 31, 2010 | 06:48 PM
morph's Avatar
morph
Dan
its just had a new paddle fitted to a standard pressure plate about 6 months ago so i dont get it! when it was first fitted and i was running in the engine it never did this, when it went back for a retune after running her in it started doing this!
Old Feb 1, 2010 | 05:13 PM
morph's Avatar
morph
i have adjusted the pedal all the way up and i think this may have cured the problem, will let you know if this is te case.
Cheers for all the help!
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
