More questions - 500 BHP
Old Jan 27, 2010 | 10:26 PM
eazy_ways's Avatar
eazy_ways
Default More questions - 500 BHP
Sorry but more questions, I like to understand the reasoning behind certain things unfortunately before committing the cash. Anyway got a few more questions regarding a YB build that will go to 5/600 bhp depending on the answers.
Best Bore and Stroke combination - also what is the maximum piston speed and at what rpm ?
Recommended suppliers/manufacturers of crank,rods & pistons
Why nikisil steel liners - why not run with bare liners ?
Maximum boost and why and at what rpm?
Suggested Cam profiles - what duration ? Lift ? Solid or Hydraulic?
Suggested Valve Spring pressure's - installed and full lift ?
Oil pump flow rate increase for the higher horsepower - if necessary and modifications required for wrc spray jets (what effect does fitting these have on oil flows/pressure?
Other than dry sump any other means of driving the oil pump in view of removing the distributor.
Suggested flywheel weight and clutch type for this range of power?
Lots of questions I know but I guess there isn't one correct answer
Old Jan 31, 2010 | 03:34 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
are u the one who posted before who is running sm4?
Old Jan 31, 2010 | 03:58 PM
eazy_ways's Avatar
eazy_ways
Yes, thanks for your previous advice (I dropped mark an e-mail to which he replied), just interested in the answers to understand the approach and reasoning for some of the modifications talked about (there seems to be quite a few ways to skin this cat).
Old Jan 31, 2010 | 04:01 PM
ajamesc's Avatar
ajamesc
yeah i guess everyone has there own way of doing it all depends on who your going to use to set it up when your finished
Old Jan 31, 2010 | 05:49 PM
eazy_ways's Avatar
eazy_ways
Default sorted now
Problem solved, going to buy dave's motor.
Old Feb 1, 2010 | 06:18 PM
Its Dave's Avatar
Its Dave
Oh yes, what a engine
chowfornow
14
Jan 5, 2019 09:01 PM
timsrs
Nov 13, 2018 11:48 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
28
Sep 8, 2015 07:10 PM
