Wiring fault on high beam wire burns/frazzles out!!
Old Jan 25, 2010 | 05:49 PM
Retrostu's Avatar
Retrostu
Exclamation Wiring fault on high beam wire burns/frazzles out!!
My mate asked me to take a look at his car for him, it's a 85' 1600 cabriolet with s1 body kit ( i know its not a turbo but didnt where else to get the best knowledge base).
The heater box motor was not working so i tried his switch on my S1 and all ok i then took my relay (small yellow one nearest the drivers side wing) out and tried in his and the blower started working all ok.
I then used another spare relay as i wanted my original back the spare he could keep same as the other in the headlight relay slot all ok lights worked fine but on high beam/flash passing light the brown/yellow wire start to frazzle and burn out.
I then changed the headlight relay back to the original one he had and it still did it.
I feel really guilty although i have not really done anything.
(blower still work though)
I hope this dose not sound toooooooooooooo confusing.
please any help advice gratefully received.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
TPM961
Jan 15, 2018 10:50 AM
jay030787
Sep 18, 2015 04:38 PM
Si B
Sep 12, 2015 06:49 AM
ward1174
Sep 12, 2015 03:34 AM
