2l esp being a guttsy mofo
Old Jan 24, 2010 | 08:09 AM
Turbo Al's Avatar
Turbo Al
Default 2l esp being a guttsy mofo
the wifes focus is being a guttsy hog. struggle to get 90-100 miles to £20 of fuel. she drives it pretty normal as she has the kids in the car,
its got a k&n panel filter a resinator removed from the airbox. when she is driving you dont hear the intake grunt
no trouble codes
any ideas?
Old Jan 24, 2010 | 10:44 AM
TomStarkey's Avatar
TomStarkey
Has it lost power, is it able to climb above 4/5k revs?
Old Jan 24, 2010 | 10:48 AM
RichieST's Avatar
RichieST
Unplug the air flow meter then take it for a drive. This will bring the engine management light on but see if it improves. To turn the light off again disconnect the neg lead off the battery for half an hour.
Old Jan 24, 2010 | 04:17 PM
fiestamk2's Avatar
fiestamk2
i get 80 miles roughly for a tenner with an inductuion kit on on my 1600se and thats with todays petrol prices and i can my car roar,its not shy
Old Jan 24, 2010 | 05:54 PM
All you need to do clear the ecu is pull the violet 2 map fuse marked KAM, for a few minutes.
I would look at emissions for a clue first.
Old Jan 25, 2010 | 05:47 AM
Turbo Al's Avatar
Turbo Al
it just got mot'd at the start of the month and passed the emissions no bother, but in fairness its got worse since then.
her last focus was a 1.8, similar fault with no codes, i ended up replacing lambda sensor, afm, and idle valve, it did have sticky revs tho and a lot more miles on it.
ill get it into the garage and get the emissions checked again
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
oilman
Aug 30, 2015 08:37 AM
Clare
18
Nov 9, 2004 12:59 PM
Stavros
48
Aug 24, 2004 07:06 PM
