how do you delete stuff from your history file????
Weird, You did click on the 'clear history' bit as well as 'delete temporary files'?
Close internet explorer and re-open.
Or if you wana get techy then right click on the START menu, select EXPLORE. Windows Explorer will open in the Documents & Settings directory for the username you are logged on as e.g. Administrator. Select LOCAL SETTINGS folder. Then select HISTORY folder and delete everything in history folder. If you break your PC dont blame me!
steve
steve
she cant stop you no, but maybe your permissions are a bit restricted, go back into control panel and choose user accounts, check your an administrator and not a restricted user or something gay like that
Thats assuming you have XP or 2000
Have you tried doing this. If your a restricted user then you probably cant though.....
....right click on the START menu, select EXPLORE. Windows Explorer will open in the Documents & Settings directory for the username you are logged on as e.g. Administrator. Select LOCAL SETTINGS folder. Then select HISTORY folder and delete everything in history folder. If you break your PC dont blame me!
steve
steve
nah she doesnt trust me on pc all day when she's at work. got it sussed now tho.
she was the administrator. guessed her password and got in that way. thanx for your help guys.
Download and run this....
http://cleanup.stevengould.org/
Great little program for deleting temp files, temporary Internet files, history etc. And no spyware. Does what it says on the tin
I install this on all my customer's PC's now and run it
One guy's machine was practically unusable, ran just this program, deleted over 90,000 files and recovered nearly 3Gb of wasted space
I don't usually download programs for this kind of thing but this one is worth having...
PMSL change yours to admin while your there and set your own password!! good to see blokes remaining on top... i'd go mad if my gf knew how to check up on me! luckily she is an IT doofus so i am ok!
