oil temp and pessure gauge
Actually not tabetha. The Focus was the first (with others following quickly after) that use the data highway signal (digital) for all the engine dials. EOBD/SCP in the case of the Mk1/1.5 Focus. There is a legacy pulse signal for speed (radio & cruise control), but even that is conditioned through the PCM.
That's why anyone doing a standalone ECU (MS, Omex, etc) HAS to retain the PCM to drive the standard instrument cluster.
Walters00007 did you mean the ST170 pod (Mk1.5) or the ST225 pod (Mk2).
Martin
Martin
Yes it can be done have done to my own 2.0 zetec you will need the dash surround from a ST170 as the gauge sits where the coin tray is.
You need to splice into your wiring loom at fuse 36, 41 and 61 then splice into the oil press light wire Orange/ Black wire and splice into the Generic Electronic module connector 104 pin 18 Orange/Black wire and splice into pin 2 and pin 10 on the DLC 9 Data Link Connectorand splice into pin 9 at the light switch connector.
The oil pressure gauge will work but the oil temp will not till you fit a oil press/ temp sender for a ST170 and you will have the ice warning light on until you fit the ice warning sensor ford want £68 inc vat for the ice sensor but if you go to rs/st spares on ebay they will supply a new sensor for £8 inc P&P.
You will also need the plugs for the gauges and sensor from a ST170 wiring loom as ford do not sell the connectors and pins can only get them if you order a wiring loom.
Interesting, but are the dials really moving correctly with the engine conditions (hot/cold, running/stationary). Do you get oil pressure/temperature on a diagnostic reader ie. ScanGaugeII.
Certainly the needles move but no one who's done this in the past 7 years has reported it working properly without a Blackoak PCM.
Martin
Martin
Hi All,
I need a bit of help, i need the number on the sticker on the wiring loom for the 2006 on st focus that plugs into thr boost and temp gauges so i can order it from ford.
I'm fitting 2006 on st gauges into 1.6tdci st replica and need all the help possible, ford need the number of the sticker on the wiring loom to locate the proper loom and connections, ebay sell loads of these gauges but nobody seems to be selling the connections or senders. Help and advise needed please.
Thanks
Gary
Thanks
Gary
Hi All,
Thanks
Gary
Thanks
Gary
I have too one focus 1.6 tdci and I want to install the same gauges but I have't the electric diagram.
deathrider666
Sep 28, 2015 06:12 PM
