Rev Counter Bouncing
Old Jan 5, 2005 | 08:05 AM
Sticky.'s Avatar
Sticky.
Default Rev Counter Bouncing
As title really, noticed it yesterday sitting in traffic. Needle on the rev counter was bouncing up & down, then car decided to hesitate then stall. Car would not re start, & after a minute or so, it fired up again & ran fine. But the same problem has happened again this morning
Any ideas what it could be
Old Jan 5, 2005 | 09:43 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Sounds like the Idle Control Valve sticking mate........I've got a fix for this.....
....just buy a Nova!!! JOB SORTED!!!
Old Jan 5, 2005 | 11:27 AM
Sticky.'s Avatar
Sticky.
Does it with the idle disconneted thou Lee
Fancy going halfs on a Nova
Old Jan 5, 2005 | 11:41 AM
nthorpey's Avatar
nthorpey
Hows you battery condition /alternator ?
Old Jan 5, 2005 | 12:03 PM
Sticky.'s Avatar
Sticky.
Im not sure mate, someone has said battery or alternator to me
I thought it was more coil, phase sensor, ign amp
Old Jan 5, 2005 | 12:13 PM
nthorpey's Avatar
nthorpey
Could be but if these components dont get a full 12v they won't function correctly, nice simple check for the batter/alt to eliminate them
Old Jan 5, 2005 | 12:33 PM
Sticky.'s Avatar
Sticky.
Thanks mate, i'll get them checked
Old Jan 7, 2005 | 05:41 PM
richm's Avatar
richm
4x4 paul?
Old Jan 7, 2005 | 06:01 PM
Alvyn's Avatar
Alvyn
phase sensor, ign amp [/quote]
i'd check these 2 in that order
Old Jan 7, 2005 | 09:26 PM
simonc's Avatar
simonc
The cause of my rev counter intermittantly jumping up & down, also jumped up & down when you started it, mine turned out to be the Ignition Amp at fault. My ign amp went down the pan after i fitted a Grp A coil. New one is ok though.
Simon.
Old Jan 7, 2005 | 09:45 PM
richm's Avatar
richm
bad wiring connections and earth connections often are masked by changing the ignition amp, which often may not be the true fault. This is especially true on 4x4 - in which case check the 3 connectors across the bulkhead above the camcover, especially the righthand one with the large wires. Disconnect them and check cleanliness of the connections. Check the connections also round the ignition amp and coil.
Also check (preferably unbolt, clean and replace) the loom earth connections on the inlet plenum and the large battery to chassis connection on the front edge of the battery tray.
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
