5 stud conversion
Old Jan 20, 2010 | 11:54 PM
Fociwill's Avatar
Fociwill
Default 5 stud conversion
i have a mk1 focus 2001 would it be possible to do a 5 stud conversion on it if so what parts would i need to get
Old Jan 21, 2010 | 05:41 PM
It's possible to have your hubs redrilled to 5 stud, assuming you have the 4 stud std wheels that will then be no use any longer can I have first dibs on them if selling them ?
Old Jan 21, 2010 | 10:07 PM
Fociwill's Avatar
Fociwill
how would i go aout getting them redrilled and yes certainly
Old Jan 21, 2010 | 10:17 PM
thebigmacmoomin's Avatar
thebigmacmoomin
I have one question .................... Why? Theres a massive amount of 4 stud wheels to choose from.
Andy
Old Jan 21, 2010 | 10:39 PM
MisiekT_PL's Avatar
MisiekT_PL
massive?! not really - there's a lot of models not available in 4x108 or models that look much better in 5 stud pattern
Old Jan 22, 2010 | 06:18 PM
Hi,
Approach a local engineering company, it is not a hard job at all(engineering wise), they will most likely either just redrill 5 holes in pcd that you want, or weld your 4 holes, skim flat then redrill to 5 holes and tap, make sure you can get the offset you need before going ahead, I'm sure you can, but wouldn't want you to go ahead and find you couldn't.
Please pm me if you are in position for a sale please, thanks, would do these in gloss black for my mercury grey sapphy!!
Old Jan 26, 2010 | 04:30 PM
Sp3no's Avatar
Sp3no
I have a cad drawing indicating where the holes need drilling, you re-use one of your existing stud positions. Im doing the same thing to fit ST220 18's to my ST170
Old Jan 28, 2010 | 03:11 PM
Fociwill's Avatar
Fociwill
Thats what i was thinkin st2 focus wheels or similar who have you got doin the work for you
Old Jan 31, 2010 | 07:23 AM
marky_g's Avatar
marky_g
Fleet Manager
transit connect hubs, 5x108,job done!
or try here http://www.ezaccessory.com/Wheel_Ada.../4000-4000.htm
Old Jan 31, 2010 | 07:33 AM
tees 21's Avatar
tees 21
Hi There would you mind sending me the drawing as i live in New Zealand and would like to get my Shapp Cossie done as there are not many 4x108 wheels available over here
Old Jan 31, 2010 | 09:05 AM
MisiekT_PL's Avatar
MisiekT_PL
marky_g - you're sure Transit Connect hubs are plug&play - that would mean easy conversion both to 5x108 and to 300mm brakes at the same time (the same brakes as on ST170 as far as I rememnber)?
Old Feb 5, 2010 | 10:59 AM
Sp3no's Avatar
Sp3no
Use mondeo 300mm brake disks and calipers, will fit on your hubs unlike the ST170 ones that require ST170 hubs, almost identical the mondeo caliper is just slightly different. Interesting with regards to transit connect hubs, will the spline pattern match that on the ST170 drive shafts?
Old Feb 5, 2010 | 11:07 AM
MisiekT_PL's Avatar
MisiekT_PL
you're telling me Mondeo calipers fit standard Focus' hubs plug&play? never heard of it before...
mk3ste
Oct 17, 2021 10:09 AM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
