judder in reverse
Hi there got an S2 rs that I am using for track days but have inherited an annoying problem when I bought the car.
Basically the whole car judders when you try to reverse it like the clutch is slipping but only in reverse. The car drives perfectly fine in all forward gears. As far as I know it has a standard clutch fitted. Does this indicate the flywheel is damaged or is the clutch going?
The Enigma
Sep 12, 2015 10:12 PM
