Manifold
Old Jan 20, 2010 | 07:19 PM
JoshXR2's Avatar
JoshXR2
Default Manifold
Hi guys,
having more troubles with the car now. Having changed the headgasket etc have now found the turbo manifold is glowing red hot after an hours cruising at 70. will the fact that i've heat wrapped the manifold turbo elbow and down pipe cause this or is there a more serious problem?
Old Jan 20, 2010 | 07:33 PM
gus's Avatar
gus
timing ok
could that not be due to too much advance????? just a guess
Old Jan 20, 2010 | 08:24 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Temps in general ok? does just sound like accumulated heat on a nice run if everything is heat wrapped. How does it pull through the gears?
Old Jan 20, 2010 | 09:05 PM
Rob_DOHC's Avatar
Rob_DOHC
turbo got all the appropriate water pipes connected? fueling all okay..... running dangerously lean can do this, as can valve timing etc.
Old Jan 20, 2010 | 09:21 PM
JoshXR2's Avatar
JoshXR2
the turbo is a series one with no water cooling. the car pulls fine through the gears the temps in general are on the low side usually runs on the m of the norm but now is well below.
The timing was set as per haynes and the 2 timing marks. Could the advance ge done by the dizzy?
Old Jan 20, 2010 | 09:47 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
excess egt are caused buy the fueling being to rich as the unburnt fuel exits the engine rather than burning in the cilinder or there is not enouth ignition advance. is it on mfi??? if so try changing the sensor in the cross over pipe for a known working one
Old Jan 21, 2010 | 03:34 PM
Rob_DOHC's Avatar
Rob_DOHC
No mate, running lean causes high egt's, running rich can actually cool exhaust valves etc.
Rob,
Old Jan 21, 2010 | 04:30 PM
jammerrs's Avatar
jammerrs
its running lean that causes high egt's, as said fuel actually cools it
Old Jan 21, 2010 | 05:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah running lean or timing too retarded.
Are you running standard boost?
Old Jan 21, 2010 | 06:01 PM
Rick's Avatar
Rick
It's too retarded, seen it loads when people have had it apart.
Old Jan 22, 2010 | 06:40 AM
JoshXR2's Avatar
JoshXR2
is this gonna be a case for a tuner to sort or can I advance it myself for the time being until I get time to get to a tuner?
Old Jan 22, 2010 | 09:40 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if it runs with too little advance or too rich, then it can cause fuel to burn in the turbo, sort of like how antilag works and cause the turbo to run too hot and cooling engine a little.
on the other hand if it's too lean and too much advance it'll send a hotter mix into the turbo in the first place so another problem.
get it over to a tuner and see what they are saying about fuel mixture and timing.
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
caprixpack
Sep 25, 2015 07:53 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Si B
Sep 12, 2015 06:49 AM
