dvd help
i bought a region 1 dvd off the net as the film doesnt appear to be availible in the uk,
is there a way to play it on an english dvd player or copy the disc to region 3?
i know i can change the region on my laptop but you can only do that a few times.
any help is apprecciated
To change code go to 'Preference Settings' in your system menu, then just type in the numbers 1, 3, 5, 5, 6, 6, select region 0 and press 'OK'.
Give that a quick try and let me know
Big-Dan.
Big-Dan.
Also, for future reference when it comes to computers and DVD region codes...
DVD drives on computers are also locked to region, and only have a limited amount of times you can change that region
But a program called "AnyDVD" will override this region lock and allow you to use discs locked to other regions. It runs as a background process.
Added to that, DVDShrink, which is a DVD reauthoring tool, and completely legal, will allow you to re-author any DVD and the output DVD will be region free. However, you will still need AnyDVD running in the background if you want to reauthor a DVD that is of a different region to that of your DVD drive.
I bought a copy of Terminator 2 that is region 1, and my DVD player is Region 2 locked, so I used AnyDVD to bypass my DVD drive's region lock in the computer, then reauthored the DVD to a region free version so I can play it. Perfectly legal as I own the source disc
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
Thrush
Jul 25, 2004 12:46 AM
