wen a garege does a set up with out a rolling road what does it involve
Old Jan 16, 2010 | 05:34 PM
dale rs1989's Avatar
dale rs1989
Default wen a garege does a set up with out a rolling road what does it involve
wen a garege does a set up with out a rolling road what does it involve.and is it worth it ??
Old Jan 16, 2010 | 05:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
You have to have it done regularly or there is a very very good chance your engine will die!
They adjust the fuel pressure by a 3mm allen key in the side of the EMFPA, and set the ignition timing by twisting the Distributor!
The timing is advanced until the point of Det then backed off a little and the full load WOT AFR is set to around 11.8:1, at your desired/safe boost level.
Then you get a nice print out showing your BHP/Torque....
Old Jan 16, 2010 | 05:47 PM
dale rs1989
and they can give u a good reading for bhp with out the rolling road ?? do u think its worth it ? might get it done think its only £50 sound right
Old Jan 16, 2010 | 05:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No you cant get a BHP reading without a RR mate.
Old Jan 16, 2010 | 09:49 PM
Rob_DOHC's Avatar
Rob_DOHC
If you have an adjustable cam pulley they may adjust that as well. Well worth it.
Old Jan 16, 2010 | 10:03 PM
andy130's Avatar
andy130
whos doing it mate?
3drRich
Sep 13, 2015 07:32 PM
Russ Hill
Aug 31, 2015 06:44 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
