DIY work on FRS
Old Jan 14, 2010 | 12:19 PM
Flipb's Avatar
Flipb
Default DIY work on FRS
Hi,
Does anyone if there is any kind of workshop manual style publication to cover the MK1 FRS?
I know that Haynes do not produce one.
Thanks.
Old Jan 14, 2010 | 08:51 PM
Zetecfiesta's Avatar
Zetecfiesta
think internet forums are going to be your only option mate if its focus rs specific other than that no reason why a normal haynes for a normal focus wouldnt be able to help?
Old Jan 14, 2010 | 08:57 PM
Flipb's Avatar
Flipb
Cheers mate.
I was thinking about a normal haynes but not sure how relevant it will be to the turbo engine. My main problem at the minute though is to adjust the tension of the alternator/ powersteering belt.
I will check outthe haynes manual anyway, just in case.
Thanks again.
Old Jan 14, 2010 | 09:28 PM
youngben's Avatar
youngben
Originally Posted by Flipb
Cheers mate.
Thanks again.
they auto tension and once nackerd you will need a new one! they are Ł105 from ford
Old Jan 15, 2010 | 11:08 AM
Flipb's Avatar
Flipb
Cheers mate,
I had a look last night and I wondered if it was. It has started to skreech slightly in the damp so its looks like I am gonna be couching up which means less money to spend on bits at autosport this weekend :-(
Old Jan 15, 2010 | 02:42 PM
youngben's Avatar
youngben
the pulleys are know to fail and make the noise! ian howell sells replacement parts of these and so do CDF on here
Old Jan 16, 2010 | 03:05 PM
CDF Racing's Avatar
CDF Racing
Former Sponsor
Nice!
Wilsfoci
15
Mar 30, 2016 10:26 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Churtz
15
Aug 13, 2015 06:40 PM
