EFi Running problems
Old Jan 7, 2010 | 04:53 PM
terribletaj's Avatar
terribletaj
Default EFi Running problems
Hi,
I have got a S1 RST that is running OFAB management, however I have a few problems.
If the ISCV is plugged in it starts fine but idles around 2500rpm, if I unplug it it idles around 1200rpm, but is a pig to start.
If the map sensor is plugged in, the car will run for around 2-3 seconds then stall, I can hold it on the pedal but it misfires and over fuels excessively. However if I unplug it, it runs alot better, but still not right. First I thought the map sensor was faulty, so I brought a new one, but it hasn't made any difference.
I've checked all the earths etc and all seems fine, but running out of things to check now.
Has anyone had a this problem? or any ideas on what to check?
Thanks
Old Jan 7, 2010 | 05:05 PM
martinmilne's Avatar
martinmilne
wat wiring loom you useing
Old Jan 7, 2010 | 05:07 PM
terribletaj
full engine loom from a fiesta turbo, it came from a S2 RST that was running beforehand.
Old Jan 7, 2010 | 05:12 PM
martinmilne
clean the iscv up 1st wat are your injectors like ? wats the vacume pipe from the map like not sure wat else i had every problem going with mine but i was on ofac hope this helps
Old Jan 7, 2010 | 05:19 PM
terribletaj
injectors have been refurbished, but I have another set of standard blues I can try, there's no leaks and i have voltage on all 4 injectors. Vacuum pipe is brand new samco hosing. I have just restored the car so pretty much everything is new, apart from the management which came from another car.
Old Jan 7, 2010 | 06:38 PM
Karlos G's Avatar
Karlos G
Balls Deep!
is the ECU chipped, if so are you running the correct injectors for that chip?
Old Jan 7, 2010 | 07:35 PM
terribletaj
No it's not chipped, running standard fiesta turbo blue injectors
Old Jan 8, 2010 | 07:14 AM
Chris69's Avatar
Chris69
have you followed the setup procedure for idle in somewhere like the haynes manual?
I've had to do mine a few times to get it right but its ok now.
without the iscv the idle should be alot lower than 1200, in fact in some cases it will be almost too low but the car should just run @ 600/700rpm.
once you plug the iscv back in the idle should fluctuate a bit then re-learn and settle at approx 900/1000rpm.
there is a set procedure to re-learn/reset the idle and it does help alot with the car idling form cold/hot and regaining idle when pulling up to junctions etc.
Old Jan 8, 2010 | 09:55 AM
O.K.C's Avatar
O.K.C
Eruption 101.3fm
sensor down..
Old Jan 8, 2010 | 03:50 PM
terribletaj
problem solved, made the biggest schoolboy error ever! had the co pot plugged into the map sensor plug and visa versa, swapped them over, now runs fine lol
thanks for all the help everyone
Old Jan 9, 2010 | 11:24 AM
Chris69's Avatar
Chris69
i must admit as far as problem solving goes i don't anyone would have guessed that lol
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 19, 2015 11:46 AM
marky_g
Aug 17, 2015 12:21 PM
Zoggon
Aug 10, 2015 10:39 AM
