exhaust studs snapped!!
Old Oct 23, 2003 | 05:43 PM
B11GNS's Avatar
B11GNS
Default exhaust studs snapped!!
have removed my turbo (after i 'creamed' it on the way home today) only to find that a lot of my exhaust manifold studs have snapped, 4 along the bottom only, has anyone got any idea why this has happened. Also does anyone also know where is the best place to get a decent T34 turbo with 360 degrees etc, taking into account my budget is not too high!!
Old Oct 23, 2003 | 10:24 PM
Mr.worth's Avatar
Mr.worth
this happend to me m8,found out it was the turbo damper and a heavy right foot.
Old Oct 23, 2003 | 11:12 PM
3drSteve's Avatar
3drSteve
Yep agree with mr worth - turbo damper - get yourself an overhaul kit for it.
Easy job.
Steve.
Old Oct 24, 2003 | 06:00 AM
B11GNS's Avatar
B11GNS
Cheers, peeps.
Old Oct 25, 2003 | 02:59 PM
cossiesfx's Avatar
cossiesfx
had the same problem ran to much boost through the t3, turbo came off snapped off one of the bolts in the head, only way to fix it was head off and drilled out so at the moment just left it slightly blowing for the moment till funds allow me to take it off.
Old Oct 25, 2003 | 04:01 PM
B11GNS's Avatar
B11GNS
does it blow a lot as i have removed 3 of the 4 broken studs and cant get the other one out and i am possibly going to have to leave it, just wandering if i could get away with it?
Old Oct 31, 2003 | 03:08 PM
cossiesfx's Avatar
cossiesfx
it blows a little but not enough to lose boost or anything, its been fine actually. i am gonna just put some exhaust sealant around it to see if that makes a difference at all.
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
