Car wont start ( video inside)
Old Jan 2, 2010 | 03:12 PM
conor.rst's Avatar
conor.rst
Default Car wont start ( video inside)
Hey all.
the cars playing up again and i can think what i could be, it was warking fine then i turned it off left it for a few hours and tryed to start it up and it just wouldent start.
heres a quick vid of wha its doing.
any ideas ??
Old Jan 2, 2010 | 03:21 PM
Billy_RS's Avatar
Billy_RS
Has it got Petrol?
Is it Sparking?
Old Jan 2, 2010 | 03:28 PM
conor.rst's Avatar
conor.rst
Originally Posted by Billy_RST
Has it got Petrol?
Is it Sparking?
Yes has over half a tank and how do i tell if its sparking ??
Old Jan 2, 2010 | 03:58 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
to check for spark, pull a ht lead off aplug and rest lead on rocker cover, turn engine over and you should see a spark.
Old Jan 2, 2010 | 04:08 PM
retro d's Avatar
retro d
Any news did you check for spark ??
Old Jan 2, 2010 | 04:13 PM
conor.rst's Avatar
conor.rst
Gunna do it now mate gimme 5 mins.
Old Jan 2, 2010 | 04:22 PM
conor.rst's Avatar
conor.rst
Yea done every single one and they are all sparking..
There dose seem to be a really strong smell of fuel when i crank it tho ...
Old Jan 2, 2010 | 04:39 PM
retro d's Avatar
retro d
Okay some ideas!!
*how good a spark are you geting is it dull ??,
*Has your car got an inertia switch in the boot.
*When you say that you have fuel can you hear the pump prime when you switch ignition on. ?
*Remove spark plugs and check if its wet with fuel, if so then you are geting fuel up to the engine.
*Worn water pump bearing this can throw the cam time out.
Old Jan 2, 2010 | 04:42 PM
conor.rst's Avatar
conor.rst
Okay some ideas!!
whats a inertia switch ??
The spark want really that bright i did have to put a fork in the end to get it to touch the rocker cover as it had a rubber coating.
i dont have a spark plug tool
Old Jan 2, 2010 | 04:52 PM
retro d's Avatar
retro d
Could be your coil pack if it wasnt that bright a spark follow the lead back from the distributer cap.
Inertia switch usually in the boot cuts the fuel pump out if you have an accident they can play up, not sure if you have one tho ??
Old Jan 2, 2010 | 04:54 PM
conor.rst's Avatar
conor.rst
Not sure if i have one or what it would look like
Old Jan 2, 2010 | 04:57 PM
rstdave's Avatar
rstdave
Unlikely you'll have a fuel cut off mate, as said does sound spark related as it's just not firing at all is it. Leads/plugs/distributor/coil to check first i'd say.
Old Jan 2, 2010 | 05:00 PM
retro d's Avatar
retro d
Yeah like I said im not sure if it does have one. ??
Old Jan 2, 2010 | 05:04 PM
jonny s2's Avatar
jonny s2
didnt you just get this setup
Old Jan 2, 2010 | 05:12 PM
retro d's Avatar
retro d
Try another distributer or check the rotor arm, havn't the distributers got an earth strap on the body. ?
Old Jan 2, 2010 | 05:14 PM
jonny s2's Avatar
jonny s2
as above try the little things first
possible timing out,or dodgy metering unit
Old Jan 2, 2010 | 05:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Do the plugs come out wet or dry?
If they are wet then it's not sparking under load (compression) or your overfuelling, if they are dry then your not getting enough fuel.
Old Jan 2, 2010 | 05:19 PM
Billy_RS's Avatar
Billy_RS
Mate forget all this inertia malarky!
Just check the simple stuff. Make sure the leads are all plugged in tight, take the plugs out have a look at them and test the spark, make sure you've got fuel getting there, check timing. It will only be something small if you only had the car running a while before it started messing about.
This is the reason i've moved away from RS Turbo's, too many headaches.
Let us know how you get on son
Old Jan 2, 2010 | 05:44 PM
ROB7656's Avatar
ROB7656
check the fireing order
Old Jan 2, 2010 | 07:37 PM
andy milligan's Avatar
andy milligan
newbe
Sounds like mine did the other day when the fuel pump stopped working.
Did you say the pump primes when the ign is switched on?
Old Jan 2, 2010 | 07:48 PM
cossie2010's Avatar
cossie2010
sounds a bit daft m8 but you tryed your compression mate as mine went like it and i had a small break in the head gasket
Old Jan 2, 2010 | 08:30 PM
conor.rst's Avatar
conor.rst
Fuel pump primes when i twist the key and it sees to be sparking fine, i have a mecanic coming out in the morn as i have given up
Old Jan 4, 2010 | 05:11 PM
retro d's Avatar
retro d
Well does it run. ?
Old Jan 4, 2010 | 05:47 PM
conor.rst's Avatar
conor.rst
Well does it run. ?
Oh yeah i changed the plugs and got it runing the bater light bulb had blown aswell that why it wasnt charging..
Old Jan 4, 2010 | 09:34 PM
Billy_RS's Avatar
Billy_RS
See, keep it simple on simple cars
Old Jan 5, 2010 | 07:28 AM
conor.rst's Avatar
conor.rst
Very much so my friend. cheers to everyone for the help.
Old Jan 5, 2010 | 04:18 PM
retro d's Avatar
retro d
Glad you got it sorted, simples
Old Jan 5, 2010 | 04:25 PM
conor.rst's Avatar
conor.rst
Cheers for the imput but have a happy face
Old Jan 9, 2010 | 08:52 PM
andy milligan
newbe
Glad you got it all sorted.
Old Jan 10, 2010 | 12:41 AM
KC-RS's Avatar
KC-RS
so you just changed the plugs and that sorted it?
JoeyBoyden
Jan 4, 2024 02:36 PM
Zoggon
Aug 10, 2015 10:39 AM
Versus_Creations
24
Aug 5, 2015 09:32 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
