machined standard pistons
im lookin at a bottom end on ebay which is meant to be low comp, spoke to the owner an he says these are standard pistons that have been machined, ad says build by jano but surely the pistons wont be able to take much,
any help appreciated as i might get it if they r ok as it works out cheaper than rebuilbing mine http://cgi.ebay.co.uk/ws/eBayISAPI.d...id=p2761.l1259
i was thinking that when i was doing mine but in the end i thought just do it properly and then ull have no worrys i know that some people have done that with standerd pistons but they have ceramic coated them, iwould just get forged its peace of mind
standard comp ratio will be fine at that power as long as its set up right it will be fine probaly get away with the rods with a set of arp's if you treat it with some respect
im asking if the standard pistons that have been skimmed in the bottom end im lookin at buying will be ok
