what afr ratio is expected at the following psi..
Old Dec 29, 2009 | 04:09 PM
dom123's Avatar
dom123
Default what afr ratio is expected at the following psi..
im just a tad worried about, my 80mph to 90mph overtaking power etc where i use a little boost for a long time... as my afr gauge is staying in the 14's i'm talking about when your cruising in the fast lane with a slight bit of boost..
what afr is expected at 0.5 bar 7psi? i'm getting 14.6
also 0.7, 0.8, 0.9 around the 14.5ish these are the readings that worry me.. not the big boost... i'm geting 14.7 ish at idle..
when i hit 1bar boost it goes 12's then at 2.0 bar plus its 11's
cheers
Old Dec 29, 2009 | 04:22 PM
mechanic28's Avatar
mechanic28
cheers
are these readings at light throttle?
also really depends whos chip it is and how its been written!
Old Dec 29, 2009 | 04:24 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I personally tend to run a little richer than that on moderate boost, but its probably not going to harm it being in the 14s, id generally aim for 13s though, but im cautious with stuff like that.
Old Dec 29, 2009 | 04:27 PM
james kiely's Avatar
james kiely
how would you get it from a 14 to a 13 reading chip? increase fuel pressure?
cheers james
Old Dec 29, 2009 | 04:28 PM
Chip's Avatar
Chip
cheers james
I was referring to on cars that I map mate, so I would simply increase the injector duration a little at that point.
Not so easy with an off the shelf chip though, you are into the realms of only being able to make global adjustments then of course, so to richen it here, would rich it everywhere.
I dont know what setup he has, so not sure if he can alter the map or not.
Old Dec 29, 2009 | 04:44 PM
dom123's Avatar
dom123
ive got a msd chip, shall i give the screw a slight twist to see if i can lower it a little? these readings are at light throttle.
cheers
Old Dec 29, 2009 | 04:46 PM
Chip's Avatar
Chip
I would speak to MSD, as they will know if that is normal operation for this chipset or not.
Stu may have found those AFRs you have there work really well on your spec of engine and hence there is no point you changing them, or he may have some good advice on how much to change them by.
Old Dec 29, 2009 | 06:06 PM
kcosneil's Avatar
kcosneil
what sort of afr would u want to see at 1.5 bar full throttle.
Old Dec 29, 2009 | 06:09 PM
mechanic28's Avatar
mechanic28
think the general rule is no higher then low 12's on full load at high rpm
Old Dec 29, 2009 | 06:11 PM
cossiedave's Avatar
cossiedave
id like to see 11.4 to 11 at 2.2 bar of boost may even be just in the 10s
Rod-Tarry
75
Oct 13, 2015 04:44 PM
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Marino
Sep 12, 2015 11:10 AM
