how do you make a rs handle?
As above. ppl taking about adj tca`s and rose joints and its all going ova me head so can somone jst explan the right way to go to get a great handling s2. When its all sorted it will be runing a big power ZVH with 17" comp MO's so not sure if that will make much difference.
Thanks
Thanks
17" wheels will not help handling to be honest.
Best thing to do is make sure the stuff already on the car is in good condition then get it 4 wheel aligned to make sure everything is knob on. If you are still not happy with it then there are full adjustable suspension set ups availabe but they need setting up professionally other wise it won't handle well at all....
I have poly bushes in most places along with top adjustable konis backs are set full hard with the front set half way, also have a front strut brace, with this set up i get very little wheelspin on hard acceleration, goes round the bends nicely too, also changed to 45 profiles on RS 7 spokes as less sidewall to flex.
TTFN PaulT
TTFN PaulT
Mine is setup tale down. It handles very well in the bends, and grip in a corner is awesome, but it's not brilliant on acceleration - quite a lot of wheel spin. If i were to drag it, id just put some drag tyres on.
ive gone for
adjustable front TCA's - allows you to adjust camber/caster or something
i think for the front wheels
Fully poly bushed front end
Strut brace
Koni adjustable dampeners with -45mm chassis dynamics springs
adjustable parrallel arms with ride and height adjustable coilovers on the back
adjustable tie bar
and MAYBE a s1 anti roll bar setup to depending on how well this all handles...
car is also on 17s
still awaiting delivery on rear suspension and running standard rear shocks and springs at the moment but the car does seem very tight around the bends...however the back end is a bit shakey LOL
bassboy
i think for the front wheelsFully poly bushed front end
Strut brace
adjustable tie bar
car is also on 17s
bassboy
Originally Posted by twin45s
paul, ur S2 dont spin due to lack of power!
only messing mate
only messing mate
no lack of power just set up how i like it and a lsd that works
132 bhp all the way TTFN PaulT
