Focus MAF
Old Dec 22, 2009 | 07:28 PM
dzs50's Avatar
dzs50
Default Focus MAF
Does a 2002 1.4 zetec se have a MAF?
There is just an empty tube where I would expect the MAF to be.
Old Dec 23, 2009 | 03:24 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
It does leaving the factory. Maybe it has some sort of aftermarket air filter/tubing etc. I don't know if they can be run without it as it needs to monitor the airflow.
Old Dec 23, 2009 | 03:35 PM
dzs50's Avatar
dzs50
The picture of a 1.4/1.6 model in the Haynes book clearly shows what looks like a MAF tube coming out of the air filter but there is no electric connector attached to the tube. When you examine it on the car it is clearly an empty tube.
Old Dec 23, 2009 | 03:42 PM
Lushy's Avatar
Lushy
My 1.4i Zetec Focus (2000 x reg) has a MAF, just looked..
Ive also got a spare one, this has the connector on etc.... .
Old Dec 23, 2009 | 05:05 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Can you upload a pic? I'm very curious now .
Old Dec 23, 2009 | 05:27 PM
fiestamk2's Avatar
fiestamk2
i heard not all of these engine came with a maf.ive got the 2001 version 1600 and i have no maf.that was the first question i asked
Old Dec 24, 2009 | 08:01 PM
dzs50's Avatar
dzs50
My manual is for 2001 - 2004 so models out side this range could be different,
Old Dec 24, 2009 | 08:20 PM
dzs50's Avatar
dzs50
How do you upload a pic. The board will not let me use an attached file
Old Dec 24, 2009 | 08:28 PM
dzs50's Avatar
dzs50
Thanks. Do you know how it controls / monitors the air flow?
Old Dec 24, 2009 | 09:28 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Default how to host pic using url.
Loads of free pic hosting sites, photobucket or the one I used.
Yea, theres no upload function here so try this.
Old Dec 26, 2009 | 02:12 PM
dzs50's Avatar
dzs50
http://omg.wthax.org/zetec_se.jpg
The top picuture shows a 1.6 engine.
You can see the MAF can but there is no electrical connections to it
Old Dec 26, 2009 | 04:46 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
The MAF is located inside the plastic tubing that goes into the air box. You can see the metal jubbely clip where the tubling detaches.
Old Dec 26, 2009 | 05:29 PM
fiestamk2's Avatar
fiestamk2
that is not a maf my friend.that part you are looking at there is the same piece i have in the garage.some cars came with them some didnt.the maf has a multiplug connection that sits on top of the maf you do not have one.
Old Dec 26, 2009 | 08:54 PM
dzs50's Avatar
dzs50
Old Dec 26, 2009 | 10:29 PM
fiestamk2's Avatar
fiestamk2
there should be a sensor on the inlet.what i can do is have alook at mine in the morning and let you no
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
