tick over rs2000,,????????
Old Jan 2, 2005 | 09:11 AM
RICH RS2K's Avatar
RICH RS2K
Default tick over rs2000,,????????
ok guys the 2k is hunting badly on tick over ive had the idle speed control valve off the side of the air box cleaned it out with still doing the same the car must hunts like mad the cuts out ,,?????????
Old Jan 2, 2005 | 11:43 AM
nicksaph's Avatar
nicksaph
hello mate
have you cleaned out the throttle body as well as this can cause the same problem,
best way is to take it off and clean it out using carb cleaner,thinners, etc and an old toothbrush,
might be worth a try
cheeRS nick
Old Jan 2, 2005 | 12:10 PM
RICH RS2K's Avatar
RICH RS2K
yeah m8 thanks 4 reply,just got it sorted ,cleaned everything again,ie plugs,idle control valve,checked all connetions,,,all running sweet thank god,,
Old Jan 2, 2005 | 01:21 PM
The Sludge's Avatar
The Sludge
garibaldi
well done rich
Old Jan 16, 2005 | 10:56 PM
16vzetec's Avatar
16vzetec
my mate had this on his rs2000 and for some reason the iscv was letting too much air in.
he took it somewhere and they just reduced the size of the holes and it works fine.
very wierd tho.
still think its a dodgy sensor or ecu myself.
Pwrs2k
120
Oct 16, 2015 03:16 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
dojj
Sep 8, 2015 08:31 AM
Adam-M
22
Aug 10, 2015 10:46 AM
