problem with vauxhall calibra - NEED A FAST RESPONCE!!
Old Dec 11, 2009 | 12:42 PM
paceo's Avatar
paceo
Question problem with vauxhall calibra - NEED A FAST RESPONCE!!
hi got a problem with my mates vauxhall calibra, none of the interior electrics work, rev counter, heated seats, fuel + temp gauge etc............
he changed the alternator but still no avail.
im thinking interior relay? what do you think?
Old Dec 11, 2009 | 12:53 PM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
Checking fuses and relays would be my first port of call.
Beyond that I would be looking to trace a short in the wiring somewhere.
Old Dec 11, 2009 | 01:10 PM
mechanic28's Avatar
mechanic28
check the connectors in the n/s/f footwell(behind the covers!)but they are corroded to fuck!!
Old Dec 12, 2009 | 11:14 AM
paceo's Avatar
paceo
had a look at tehe relays and theres only 3 of them, they look ok, didnt have time to check the footwell cover as we were busy!
radio does not work either, but lights and horn do work?
Old Dec 12, 2009 | 11:43 AM
stuboy's Avatar
stuboy
search on here...
http://www.vauxhallownersnetwork.co.uk/
http://www.clubcalibra.com/
Old Dec 12, 2009 | 04:31 PM
ANDYRACER's Avatar
ANDYRACER
The more turbos,more fun!
It is all on one fuse iirc, my old cavalier did the same.
Old Dec 12, 2009 | 04:53 PM
BigErn's Avatar
BigErn
Fuse rings a bell for that problem. Sure I had a cavalier that did that.
Old Dec 13, 2009 | 11:57 AM
paceo's Avatar
paceo
any ideas what fuse mate? or relay do you mean?
Old Dec 13, 2009 | 12:15 PM
rik-rs's Avatar
rik-rs
i`d check every fuse, i had wipers not working once, checked the fuse, was ok, then started stripping wiper switch to pieces, then a mate turned up and said check all the fuses, i said ive checked the wiper one, turns out the labelling on the fuse box didnt match, and it was a fuse....
Old Dec 13, 2009 | 12:31 PM
fordpop's Avatar
fordpop
Just look in the handbook or on the lid of the fuse bax and see which fuse is the required one, if not just check each one in turn, it ain't a hard job!
Old Dec 13, 2009 | 02:12 PM
bigal1978's Avatar
bigal1978
had a citreon berlingo do the same was a fuse
Old Dec 13, 2009 | 03:28 PM
quality motor.
Old Dec 13, 2009 | 04:57 PM
RichieST's Avatar
RichieST
My astra did that, as said above, cheack the big connector block in the passenger footwell on the left. My bet is that its full of water! I just snipped the wires and soldered them together to bypass the connector.
Old Dec 13, 2009 | 07:28 PM
BigErn's Avatar
BigErn
IIRC on the fusebox cover there are some labelled K(then number) I believe one of those was the fault on mine. Defo check EVERY fuse to eliminate that option.
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
