Where do i stand with this issue.
Old Dec 10, 2009 | 05:50 PM
CabrioTurbo's Avatar
CabrioTurbo
Default Where do i stand with this issue.
2 yrs ago i had an issue with my cosworth where the waste gate arm snapped on the turbo.. while that was off i decided to have the head gasket changed to sure things up a bit.
i had the work done at the ford garage where i work and everything seemed fine.
i have hardly used the car since (less than 2k miles) but had noticed that i had a slight drip of water down the side of the block.
to investigate i had the exhaust manifold removed to see if cahnging the core plugs would solve the issue, when the mechanic removed the manifold water came out of one of the stud holes!!!
he thought the head was cracked but after removing it it is evident that when work replaced the head gasket and refitted the turbo someone has helicoiled the thread and gone throught into the water jacket!
it has not become evident as there has only been a slight drip as the stud has stopped most of the water.
I am now left with a damaged head that prob cant be fixed and the cost of replacing the head gasket due to the fault of the garage.
the issue is the work was done 2 yrs ago (still have bill for car etc) and is obviously out of warranty.
where would i stand as it is evident that the original job however long ago it was done was not completed correctly and the helicoiling has damaged the head?!
Many thanks
Phil
Old Dec 10, 2009 | 05:52 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
You could have heli'd it yourself then gone back after messing up.
That is how they will see it and will probably just tell you to go fish. You'll struggle to prove that after 2 years it was indeed their workmanship that caused the issue.
Old Dec 10, 2009 | 05:54 PM
tonytantrum's Avatar
tonytantrum
most garages only offer a 1 year warrenty i know the garage i work does! only thing you can do is talk to them but i dont think you will get far. sorry mate
tony.......
Old Dec 10, 2009 | 05:59 PM
CabrioTurbo
have spoken to them but not sure what will happen just really pissed off that i know the damage was done then, and there have been no symptoms until now.
Old Dec 10, 2009 | 06:03 PM
polly_x's Avatar
polly_x
Cant see you getting anywhere.
Personally I would use plenty of Loctite liquid PTFE on the stud and the hole to get a seal with the stud in place. Nothing to lose trying?
Old Dec 10, 2009 | 06:07 PM
Toe Knee's Avatar
Toe Knee
surely the hole can be welded up and the re-drilled and tapped or helicoiled again?!
Old Dec 10, 2009 | 06:09 PM
TIFF's Avatar
TIFF
Chasing Radders
nothing you can do mate......
Old Dec 10, 2009 | 06:22 PM
S1's Avatar
S1
Ive used chemical metal quite successfully on a Zetec Turbo that leaked oil past an exhaust stud.
Old Dec 11, 2009 | 09:09 AM
CabrioTurbo
looks like i will have to try either welding the hole up or using liquid metal on there havent got the money to be buying a new head at this time of year. hopefully that will do the job. like you say nothing to loose!
Old Dec 11, 2009 | 09:14 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
The garage will tell you to stick it! Even if you went back the next week I doubt they'd do anything about it.
The 'liquid metal' option is IMO the best bet, and will probably put an end to the problem.
Old Dec 11, 2009 | 09:59 AM
cossiejay's Avatar
cossiejay
i would say you have not got a leg to stand on after 2 years
mk3ste
Oct 17, 2021 10:09 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
37
Sep 17, 2015 05:05 PM
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
