2wd Gearbox Problems
Have a screeching noise coming from my gearbox
It sounds similar to the noise you would expect from a dry bearing.
Only appears to occur in 5th gear (50-70mph) when engine on light load, once you let off it goes away. (and in neutral when free wheeling)
Anybody experienced this?
I have changed gearbox oil and still made no difference.
I might be wrong but in the T5 if 5th goes it's shagged as they can't be fixed.
They aren't expensive though to replace...................
I remember paying about £350 installed for a recon one at Harvey's
Originally Posted by alan rainbow
why cant 5th gear be fixed you can buy all the parts for a t5 box
I had 2 T5 boxes go and it was just as easy to fit a recon one.As I say, I am no technician and can only go on memory (1 year without a Cossie) but think I can remember Harvey saying that 5th gear is a bitch to fix if you can fix it at all.
As I said, I might be wrong!! Surely somebody on here can be just a teeny bit better qualified to post than me?
van_dogg_pavvy
Mar 3, 2016 09:30 AM
James Porter
Oct 28, 2015 12:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
