best place to get wires from engine bay to inside
Old Nov 29, 2009 | 10:07 PM
marky_g's Avatar
marky_g
Fleet Manager
Default best place to get wires from engine bay to inside
as above space looks abit tight under the bonnet cant rely see a sutiable gromet
where have ppl used?
Old Nov 29, 2009 | 10:35 PM
delterflier's Avatar
delterflier
ive got a 03 plate focus
the only way me and a mate found was to feed the cable from the bay in to the passenger arch(between the splash cover and the arch) then throw a gromet in the pass footwell.
my mate done most of it as i had 3rd degree burs on my hands but thats what i remember him saying he did.
hope it helps
john
Old Nov 30, 2009 | 08:09 PM
marky_g's Avatar
marky_g
Fleet Manager
ah right sod it i'll make my own hole then i cant seem to see where the main egine loom passes through that was all
Old Nov 30, 2009 | 08:49 PM
Sp3no's Avatar
Sp3no
Very difficult to get wires from the engine bay into car the usual way. So the accepted way is to go over the fire wall on the passenger side, over the bonnet hinge, tuck the wire under the top of the wing and take it through the blank grommet in the passenger side door shut. You wont notice the wire
Old Nov 30, 2009 | 09:54 PM
marky_g's Avatar
marky_g
Fleet Manager
anyone got any pics???
Old Dec 2, 2009 | 12:36 PM
Sp3no's Avatar
Sp3no
If you look behind the passenger turret you will see a loom running through the fire wall through a rubber grommet, take a wire through here, under the scuttle panel and thread it between the top of the wing and body, the wire will then be at the back of the door shut. You will see a plastic blanking grommet in the door shut above where the door loom attaches, poke the wire through here and feed it into the car. You will need to remove the kick panels to get at the wire once its in the car. Can be fiddely. I assume its amp wiring?
Old Dec 2, 2009 | 07:34 PM
marky_g's Avatar
marky_g
Fleet Manager
fukin hell that sounds abit dodgy mate. passing wires over panels. but if its the only way i'll give it a go, i'll get some info from a tech seet through work
Old Dec 3, 2009 | 08:54 AM
Sp3no's Avatar
Sp3no
The wire will end up tucked under the wing in the panel gap, so it will not be seen, when i first heard i though fuck there must be a better way, but this is the easiest by far, drilling the bulkhead is risky, too much on the cabin side that you could drill through.
Old Dec 3, 2009 | 03:41 PM
focusv8's Avatar
focusv8
Behind the dash
Old Dec 3, 2009 | 08:39 PM
marky_g's Avatar
marky_g
Fleet Manager
or right cool i may give the mail loom gromet a go, i fit after market parts for a living but mainly to vauxhall and SHITrens never worked on a ford, when i fit an alarm its gonna mean drilling and grometing
failing that suppose its the wing way
j.hammond1
30
Oct 31, 2021 05:28 PM
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
track.focus'd
Aug 12, 2015 05:53 PM
yawiejon
15
Aug 9, 2015 06:36 PM
