Small turbo engine management light
Old Nov 25, 2009 | 11:46 AM
cossie_mike's Avatar
cossie_mike
Default Small turbo engine management light
Last night i changed the shitty bleed valve that was fitted and but back the amal valve the car run sweet for the first 15-20 mins then the two lights that are above the clock came on and the car run ruff as fooook there was also a strong smell of fuel when this happend.
Think it could need setting up!!!
Thanks
Mike
Old Nov 26, 2009 | 10:18 AM
Toymota's Avatar
Toymota
cossie_mikes biatch
very helpful the guys on here arent they
lol
Old Nov 26, 2009 | 10:53 PM
GUZZLER's Avatar
GUZZLER
if the amal valve wasn't plugged in before then unplug it again, Theres nothing wrong with bleed valves, there crude but they work! the problem is that there to easy for people to adjust when they don't know what there doing.......
what boost is it running? is it chipped? if you have altered the boost then it may be detecting overboost.
Old Nov 27, 2009 | 07:28 AM
Toymota's Avatar
Toymota
cossie_mikes biatch
we got the diva to run a test on it and it turns out it might be the chip so going to remove it
Old Dec 3, 2009 | 07:38 PM
MarkN's Avatar
MarkN
Do you mean the red and amber light on the clock? If so this is the frost warning light.
I didn't think the small turbo even had an engine management light...
Old Dec 4, 2009 | 08:56 AM
phs84's Avatar
phs84
and one of them is for the anti-theft-advice and the alarm!
regards,
phil
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
CrOwSoN15
Aug 14, 2015 06:52 PM
Old ford
Jul 31, 2015 06:50 AM
