hoses??
Old Dec 30, 2004 | 10:35 AM
righthooker's Avatar
righthooker
Default hoses??
my new i/c has standard pipes ,the turbo looks like around 50mm. on the cold side the outlet is also standard (63mm?)is the diamiter the same at the throtle inlet bit.
samcos must come in the same size ,but have all turbos the same outlet size eg T3 T34(50mm.) the probs i am having with my hoses i am thinking of going out to get some samcos to compare.my turbo side hose seems to reduce too quickly at the cooler that it kinks when atached to the turbo ,so i was wondering if the samco reduces maybe a little later??
all help apreciated as i am now getting frustrated with my self .Thought even i could fit a cooler without probs but no!!!!!!!
Old Dec 30, 2004 | 10:38 AM
TIFF's Avatar
TIFF
Chasing Radders
DONT GET SAMCO's as there shite
Get Roose Motorsport hoses
Speak to Stretch as he is a dealer for them
Old Dec 30, 2004 | 10:53 AM
righthooker
i want roose to be honest but i want em now so i can get my car going
Old Dec 30, 2004 | 10:54 AM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
righthooker, I agree..roose are the fellas.. you can actually speak to them and tell them what you want..friendly fast service too...check out their silver hoses, they look really trick!
Old Dec 30, 2004 | 10:58 AM
Ryan's Avatar
Ryan
Pro- Just a quick question can you make alloy boost hoses?
Old Dec 30, 2004 | 11:01 AM
wayneclayden
590 BHP/Ton
Ryan, trying not to really!!!sorry bud...have you tried lee @fusion..he does them, cheap too!
Old Dec 30, 2004 | 11:02 AM
Ryan's Avatar
Ryan
no worries just a thought.
Yeah i know Lee does them, he was the next port of call
Old Dec 30, 2004 | 11:40 AM
3drstretch's Avatar
3drstretch
You have a PM mate
MM_RACING's Avatar
MM_RACING
Paul @ Roose Motorsport hoses - Two weeks for black hoses
ROOSEMOTORSPORT@aol.com
Great service and super fast
Samco - Six weeks for black hoses
Old Dec 30, 2004 | 01:34 PM
Paul.'s Avatar
Paul.
Default Boost hoses.
The standard intercooler outlets are 60mm external diametre at each end.
The standard throttle body is 63mm external diametre.
The T3 & T34 turbo outlet is 51mm external diametre.
The T3 inlet is 60mm external diametre.
The T34 inlet is 70mm external diametre.
The T38 outlet is 63mm external diametre.
The T38 inlet is 70mm external diametre.
The T4 outlet is 63mm external diametre.
The T4 inlet is 76mm external diametre.
The problems occur with the hoses when after market intercooler manufacturers make both outlets straight out at 90 degree's.
The standard intercooler outlet on the turbo side is angled towards the wing.
The standard turbo to intercooler hose will fit but it has to be cut down. for straight outlet intercoolers.
PS i manufacture polished stainless steel boost pipes for this conversion.
Hope this has helped.
Regards Paul.
Old Dec 30, 2004 | 07:39 PM
righthooker
am i reading corectly in thinking your hose would also need to be cut down and joined in the middle.
I just wrote a huge long pm to stretch on this i will send it to you paul
Old Dec 31, 2004 | 12:09 PM
Paul.'s Avatar
Paul.
Default T3 boost hose
You would only have to cut it to suit at the end it goes onto the turbo charger not in the middle.
With conversions like this i leave the hose long so you can cut it to your car.
Regards Paul.
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
