Ib5 wrc racing gearbox internals
PRELIMINARY SOLD FOR £100 to Will @ M Developments
Ib5 gearbox internals from a group a rally car
close ratio gears will be perfect for a track project.
Everything full recon'd and all you'll need is the gearbox casing
i also have a lightweight flywheel from the same car
included
Primary & Secondary Shafts
Selector Forks
5th Gear Bearing Carrier Plate
Standard Diff
Crown wheel
Reverse idler
The gear ratio's are...
1st - 3.583
2nd - 2.038
3rd - 1.414
4th - 1.108
5th - 0.078
Reverse - 3.615
The final drive ratio is 3.824
included
Selector Forks
Standard Diff
Crown wheel
Reverse idler
1st - 3.583
2nd - 2.038
3rd - 1.414
4th - 1.108
5th - 0.078
Reverse - 3.615
It was running a car with 460hp..
I've got some doc's somewhere - not sure on the value to be honest but open to any offers as my project is over and I've stop racing.
i need a decent gearbox for my rst will be 300hp+ ive no idea on the price,you must have a figure in your head,so would i need a ka box,could i use the rst casing,have you a lsd? quaife?
Selector Forks
Standard Diff
Crown wheel
Reverse idler
1st - 3.583
2nd - 2.038
3rd - 1.414
4th - 1.108
5th - 0.078
Reverse - 3.615
Selector Forks
Standard Diff
Crown wheel
Reverse idler
1st - 3.583
2nd - 2.038
3rd - 1.414
4th - 1.108
5th - 0.078
Reverse - 3.615
The Youth.
Sep 30, 2015 09:59 PM
