Heater Fan Speed not working FRS
Old Nov 17, 2009 | 10:32 PM
Irish aRSe's Avatar
Irish aRSe
Default Heater Fan Speed not working FRS
Alright Lads,
I'm new to the site but have been an RS nut all my life. I have a 03 FRS at the moment and a slight issue with it.
The heater fan speed only works on setting 4. 1,2 and 3 nothing happens. Anyone got any ideas?
cheeRS
Pat
Old Nov 18, 2009 | 12:47 PM
martysmartie's Avatar
martysmartie
Yes you need to replace the resistor pack in the passenger glove box.
Martin
Old Nov 19, 2009 | 04:46 PM
STbash's Avatar
STbash
definately the resistor pack..
if its anything like a normal foci get your head down in the passanger footwell and remove the carpet trim under there, look up and you can see the blower unit, big round thing.. to the rear of that is a small blue box looking thing about an inch by 2 inch.. replace it. behind the glove box is also a good place to access it as martysmartie said.
salvage yards are a good place for them though being a common focus gripe you might be hard pushed to get one?
try the bay bud, plenty on there..
Old Nov 25, 2009 | 12:48 AM
Irish aRSe's Avatar
Irish aRSe
Spot on removed it and did a continuity check across it. None across one of the pins and slightly corroded. Getting a new one from Ford. Pain in the aRSe to get at though. Thanks again lads.
Was thinking of heading over to UK. Are any shows or meetings coming up?
cheeRS
Kyle Langford
27
Aug 5, 2019 07:54 PM
Zoggon
Aug 10, 2015 10:39 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
