focus tail lights and dash lights not working
Old Nov 17, 2009 | 07:15 PM
RUBY123's Avatar
RUBY123
Default focus tail lights and dash lights not working
as titled really no dash light or tail lights working or side lights. checked all fuses and there fine also changed light switch and still nothing. anyone got any ideas its a 02 plate ghia if it helps thanks
Old Nov 17, 2009 | 07:51 PM
martysmartie's Avatar
martysmartie
You did check the fuse box inside the car opposed to the under bonnet one?
Martin
Old Nov 17, 2009 | 10:44 PM
RUBY123's Avatar
RUBY123
yes checked that one I've been looking on the net and apparently its quite a common problem but no one ever says the solution. i no its no fuse related as well because the other day all the lights came back on and lasted 2 days but now completely gone
Old Nov 18, 2009 | 12:29 PM
martysmartie
I wonder if it's the switch, does the front sidelights work?
Martin
Old Nov 18, 2009 | 01:33 PM
RUBY123's Avatar
RUBY123
nope no side lights just full beam and main beam and bought a brand new switch and no difference and it cost Ł60
Old Nov 18, 2009 | 01:35 PM
RUBY123's Avatar
RUBY123
also front bottom fogs work indicators work brake lights work rear fog light works
Old Nov 18, 2009 | 01:46 PM
Brian ST-2's Avatar
Brian ST-2
Happened to a guy at work's Mondeo just last week, he had no rear sidelights and no dash lights.
Guy at the garage checked all the connections behind both fuseboxes and switches and the problem solved itself.
So although the fuses may be fine, it may be behind there one of the connections is causing the problem.
Good luck
Brian
Old Nov 18, 2009 | 05:32 PM
RUBY123's Avatar
RUBY123
yep tried that still no joy but thanks for the suggestion. the strange thing is with the ignition off and the parking lights on which are the tail light and the side lights they work fine
Old Nov 19, 2009 | 03:45 PM
RichieST's Avatar
RichieST
My money is on an earthing fault somewhere. I'd get it to an auto electrician, they should get it sorted in no time.
Old Sep 22, 2021 | 09:00 AM
Jitterbug's Avatar
Jitterbug
I have this exact problem, how did you mend it?
Old Sep 22, 2021 | 02:09 PM
GVK.'s Avatar
GVK.
Thread is from 2009, very much doubt they still post here.
Old Oct 4, 2021 | 06:10 AM
rayben's Avatar
rayben
Check the wiring harness particularly the one in between the gate and body.
track.focus'd
Aug 12, 2015 05:53 PM
turbobill
Aug 1, 2015 08:55 PM
Graceland
Jul 31, 2015 10:34 AM
