Engine management light
Old Nov 17, 2009 | 11:17 AM
DMR's Avatar
DMR
Default Engine management light
Is there a way to check if the engine management light is working? My car is playing up and has been for a few months but the light has never come on, the bloke/Garage i got the car from is known for removing the bulbs if he cant get it to turn off and i wanna check mine.
Any ideas?
Old Nov 17, 2009 | 01:09 PM
Sp3no's Avatar
Sp3no
When you turn you igntion on the engine managment light should come on, it will stay on until you car is started then go out shortly after. If its not coming on at this point the bulb is blown or its been removed
Old Nov 17, 2009 | 01:33 PM
DMR's Avatar
DMR
are they hard to replace?
Old Nov 17, 2009 | 01:52 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
the bulbs?
just take the clocks out
if you want to run a code reader on the car incase its got any stored error codes i have 1 in beccles
its very good, just takes a second or 2 and can clear codes for ya too
Old Nov 18, 2009 | 12:52 PM
martysmartie's Avatar
martysmartie
Codes can be cleared anyway be resetting the KAM
Martin
Old Nov 18, 2009 | 04:28 PM
DMR's Avatar
DMR
emailed my local ford dealer to order a bulb, they said theres 2 kinds so had to take the one in there out and take in with me, so did that today but there was no bulb in there to start with lol so i took the one that is used for the seatbelts out and put that in the one thats missing and it worked fine also went out when i started the engine. so now i have no idea what so ever as to what is wrong with me poor car
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
