RS Turbo starter motor
Old Dec 29, 2004 | 04:50 PM
Moonie's Avatar
Moonie
Default RS Turbo starter motor
My starter motor has started no starting
I beleve there is a difference between the turbo starter and other starter motors, is this true? I know the starter off any cvh will bolt on and work but are the internals any different to cope with the heat from the turbo?
This is my second starter to go in 12 months, last time it went i replaced it with a £30 starter from the local car accessory shop. Am i best off goin to ford and paying the extra £££?
Also there is a heat sheild available from ford to cover the starter and solenoid, any one fitted/used one?
Old Dec 29, 2004 | 05:13 PM
DOO's Avatar
DOO
Ford price rst starter £71.71+ vat retail is not that bad for genniue parts.
even cheaper with trade discount about 20%
Get a full 1 years warranty so if it breaks they would even fit it for you
If you planning to keep the car i would get a ford one
But you do get what you pay for
there is a small heat sheild for the stater about £18 qiud still avab
I would get the finns codes for you but not back to work untill next Tues
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
the heat shields are fitted as std afaik, up to you if u get one or not really it'l prob help to some extent,
why not open your starter up, 9 times outa ten if its newish its jus run dry with no grease in it due to the heat.
the terminals are diff depending on what year afaik!
I got a re-con starter exchange for £55 with 1yr waranty.
Old Dec 29, 2004 | 05:16 PM
essexrsturbo's Avatar
essexrsturbo
mines done exactly the same 2day!
Old Dec 30, 2004 | 10:50 AM
Moonie's Avatar
Moonie
Just phoned ford for a new starter, they want to know the kilo watt rating of the starter motor fitted to my car
Anyone any idea what it is? I cant get to the car to look till later and i need to order it now.
Old Dec 30, 2004 | 12:27 PM
DOO's Avatar
DOO
sorry mate finns 1008828 starter
Old Dec 30, 2004 | 12:56 PM
Ben's Avatar
Ben
And the FINIS for the heat shield is 1644016
Old Dec 30, 2004 | 03:58 PM
Moonie's Avatar
Moonie
Cheers people
Been to Ford and got my new starter motor (finns#1008828), heat sheild is coming tomorrow
Just had a look at the starter, attached to it is a piece of paper with a diagram of the starter motor. It also shows a heat sheild with a cross through it, does this mean the heat sheild will not fit or is not needed/recommended?
Old Dec 30, 2004 | 05:42 PM
townie9371's Avatar
townie9371
on my last rst i bought a 1.6 cvh one from a scrappy was on for 4 years and still worked perfectly when car was sold.why spent 90plus quid
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
