evolution chip ALS wiring
Old Nov 16, 2009 | 06:53 PM
MONTE 005's Avatar
MONTE 005
Default evolution chip ALS wiring
hello everyone,
is stewart around pls or can anyone help me with the bloddy wiring for the anti lag system???? we have located the 3 pin connector but we are blind in choosing the right wire any help pls
Old Nov 16, 2009 | 07:09 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
If you get a multimeter place it on continuity - you need to check which one of the 3 pins goes to pin 13 (Check your paperwork to confirm this is the allocated pin). This is the wire to earth through a switch to activate your anti-lag.
From memory, it is the left hand side one of the pins in the triangle when looking at it, but please check that.
Old Nov 16, 2009 | 07:15 PM
MONTE 005's Avatar
MONTE 005
cheers mate i 'm going to check right now will let you know in 5 min.
thanks a lot!
Old Nov 16, 2009 | 07:37 PM
KSA-Cossie's Avatar
KSA-Cossie
Love my als.
Old Nov 16, 2009 | 07:50 PM
bad boy rs's Avatar
bad boy rs
im getting jelous all this talk about als, i need to purchase
Old Nov 16, 2009 | 08:10 PM
LHD220Turbo's Avatar
LHD220Turbo
you wanted a skyline!?
Old Nov 16, 2009 | 08:17 PM
jason 3dr's Avatar
jason 3dr
the flames are good to
Old Nov 16, 2009 | 08:32 PM
bad boy rs's Avatar
bad boy rs
changed me mind
Old Nov 16, 2009 | 08:34 PM
MONTE 005's Avatar
MONTE 005
anti lag installed!! thanks for your great help.
it's the left bottom pin of the triangle!
is it normal that when you activate anti lag on 1000 rpm (idle)
the revs drop to about 700rpm?
Old Nov 16, 2009 | 08:38 PM
LHD220Turbo
changed me mind
that was quick! lol
Old Nov 16, 2009 | 08:41 PM
bad boy rs's Avatar
bad boy rs
that was quick! lol
I know, put loads of work into me car and realy dont think i could sell it, plus i drove it the other day for the first time in 3 months and i was buzzing
Old Nov 16, 2009 | 08:42 PM
LHD220Turbo
that's why we love em!
Old Nov 16, 2009 | 08:46 PM
bad boy rs's Avatar
bad boy rs
so whats the crack with als, can it be used on a standard t34 in mild form ? do you just need the msd chip ?
Old Nov 16, 2009 | 08:52 PM
Big Will_'s Avatar
Big Will_
Glad it's working! Yes, some idle speed reduction can occur with the ALS on as the ignition is retarded at that point.
Old Nov 17, 2009 | 06:52 PM
MONTE 005's Avatar
MONTE 005
tryed the car today and belive me it was one hell of a buzzzzzzzzz
it was throwing 2 to 3 ft flames and the power improvemnt with the new 380 chip was amazing.......we installed this not on my monte but on a dax rush quattro cosworth!! about 750 kilo cat .........
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
