What would cause a bad oil leak.....
Old Dec 29, 2004 | 03:52 PM
wildheart's Avatar
wildheart
Default What would cause a bad oil leak.....
.......when thrashing a car on track?
The car will not leak at all on the road no matter how much abuse you throw at it
After 20 mins on track my fiesta rs1800 was pissing oil out but now it wont do it at all on the roads etc
Had it at a mates garage on ramps,tried thrashing it etc and looking at it but there is no sign of where its coming from
Could it be the oil getting to hot thats causing it?
Old Dec 29, 2004 | 03:54 PM
M K's Avatar
M K
no idea
fit an il cooler & see if it stops (the track leak)
not cheap but a worthwhile mod anyway
Old Dec 29, 2004 | 03:58 PM
wildheart's Avatar
wildheart
Depends if i keep the car with the luck im having
Hit a fox last night so damaged bumper
Old Dec 29, 2004 | 04:00 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
could be a leak on the side of the sump an leaks underhard cornering at high rpms
Old Dec 29, 2004 | 04:03 PM
CraigN's Avatar
CraigN
zetec sumps very rarely leak as the sump has groove cut into it which the gasket sits in.
do you have no indicatino of which area of the engine its coming from ?
Old Dec 29, 2004 | 04:06 PM
wildheart's Avatar
wildheart
The oil is mostly been leaking over the paaenger side of the bay
Old Dec 29, 2004 | 04:09 PM
gearboxman's Avatar
gearboxman
If you are running Castrol RS, when hot, this oil expands significantly.
This could be giving you a "false overfill".
The oil only gets to a significant high temperature when the engine is worked hard, and has no real relationship with the coolant temperature.
The excess oil will quite possibly find its way to obstructing the breather system. If this occurs, oil will be forced through all of the oil seals.
Check oil level after 5 laps
Fit an open breather system to a catch tank (1 litre)
Old Dec 29, 2004 | 04:18 PM
wildheart's Avatar
wildheart
Im running Halfords finest 5/30!!!!
Old Dec 29, 2004 | 04:19 PM
AlexF's Avatar
AlexF
Bernie I was about to suggest the same thing...
many oils do the same and then leak out...
my rs2k did that on track if the oil was on the full line of the dip stick.. half a nats cock under it and no leaks at all
Old Dec 29, 2004 | 04:45 PM
gearboxman's Avatar
gearboxman
Great minds think alike
Old Dec 29, 2004 | 04:53 PM
xr2i-carl's Avatar
xr2i-carl
my mates old cvh 1.6 shit box escort used to piss out oil after doin reverse doghnuts!!!! but never leaked otherwise, but if he did reverse doghnut it pissed out oil everywhere
STRANGE
Old Dec 30, 2004 | 04:46 PM
wildheart's Avatar
wildheart
Sounds like an oil cooler is needed then!
TPM961
Jan 15, 2018 10:50 AM
A.t.p
Sep 29, 2015 05:04 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
